Sun, Feb 2, 1:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Subject: questions for poser 5
Shaddex ( ) posted Sun, 22 August 2004 at 5:09 AM ยท edited Sun, 02 February 2025 at 12:41 AM
I think I posted this the first time ni the wrong forum >.< anyway.. 1. How do you apply a background/sky in poser? And ground/water? I herd others doing it but cant find anyway to do it myself. All I can get it to use is a soled color for the background. I had a nice Sean set up but couldnt get the background image or any sort of ground to display. 2. How do you directly edit a model? Like making something longer, shorter, thinner wider, adding spikes and new moveable sections. With out using the scale and distorting other parts of the model? 3. How on earth do you add a skin to a model that dont have a skin to start with? I have a few models that didnt come with skins, but found some that were made for them. But when I add the skin, it dont display on the model.. Yet if I do it to the default models that come with poser 5 the skins load and display fine. 4. How do you make a smart prop? I have a prop I made and would like to turn it into a smart prop, but have no idea how to do such. Thanx in advance.
geep ( ) posted Sun, 22 August 2004 at 5:54 AM
Hi Shaddex, 1. Backgrounds? ..... [ TRY THIS.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1839126) 2. Editing a model? Sounds like an MT is needed. You might want to [ GO HERE.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1843595) 3. Skins? You might find an answer [ HERE.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1663563) 4. A smart prop is a prop that has been "parented" to something. When that prop is saved, Poser will ask if you want to save it as a "smart prop?" If you answer "YES," Poser will remember the parenting data so that it will automatically be parented when you load it from the library. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Shaddex ( ) posted Sun, 22 August 2004 at 12:55 PM
Cool.. but is there anything on making water? Like for lakes and such? Like water thats transparent and all?
geep ( ) posted Sun, 22 August 2004 at 1:43 PM
Water? ................ Sure ... ;=] ... check out Page 16 in [ THIS TUTORIAL.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1642292) cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 22 August 2004 at 1:47 PM
And if you want to make the water rough ... ... See [THIS ONE.](http://www.renderosity.com/messages.ez?Form.ShowMessage=1867126) cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
