Sun, Jan 12, 2:15 PM CST
Subject: Doors & Windows
Rebecca Lee ( ) posted Thu, 09 November 2000 at 4:30 PM · edited Sat, 03 August 2024 at 7:30 AM
I have Bryce 4, Paint Shop Pro 5, Cad 3D and 3D Architect Deluxe and here's my questions. Can I make doors and windows for a castle with Paint Shop Pro 5 and easily use them Bryce? Also 3D Architect Deluxe will export to dxf, but Bryce doesn't like the dxf and imports it flat? Love Always, Rachel
Flickerstreak ( ) posted Thu, 09 November 2000 at 6:22 PM
Well, you can make doors and windows in Paint Shop Pro if you make them as grayscale-to-height maps. You can then colorize those maps for the textures. Check out some of the tutorials (see the tutorials link on the sidebar) for details. DXF was originally a 2-D file format for describing architectural and engineering drawings. It was later expanded to include 3 dimensions. Your 3D Architect program may just be exporting the 2-dimensional floor plans to the DXF file - you'll have to check the documentation for that software. Bryce usually will either completely import a DXF model correctly, or it will choke and complain that it couldn't import the file at all. I've never seen it import a 3D DXF file as 2D: most likely, 3D Architect is saving the file as a 2-D floor plan. cheers --flick
3ddave44 ( ) posted Fri, 10 November 2000 at 12:08 PM
You can make the doors and windows as greyscale models as flick said - but I suspect since you ask at all that that may be advanced for you... so the answer that you probably can actual deal with is this: yes, make any graphic or photographic graphic of a door or window and use it as a texture map on cube shaped as a door or a wall, etc. There are a number of places online where you can download window and door textures to try it out with before you make your own - including www.marlinstudios.com, or www.3dlinks.com under free textures. - Dave www.citizendave.com
