Mon, Feb 17, 8:06 PM CST
Forum Moderators: RedPhantom
Subject: Firefly Rendering Problem. Smooth polygons problem
nio103 ( ) posted Wed, 25 August 2004 at 11:49 AM ยท edited Sat, 01 February 2025 at 7:17 AM
IM having a problem with this staff. when render with smooth polygons checked it inflates the pole. how can i fix this. here is a picture of the pole and the smooth poly one. I was thinking maybe its suppose to have a polygon in the middle/center of pole.
Manuel(Nio)
shazz501 ( ) posted Wed, 25 August 2004 at 12:00 PM
one way to stop it is to make sure you have the staff selected and click the properties tab in the parameter dials box and unclick smooth polygons,that way you get the smoothing on everything except the staff,i hope this helps :D
nio103 ( ) posted Wed, 25 August 2004 at 12:04 PM
Thanks ill try that, this place gives quick responses. manuel(Nio)
lupus ( ) posted Wed, 25 August 2004 at 12:06 PM
Hi Manuel! Put some polys very, very, near each end of the pole ("knife" or "bandsaw" it in LW) You could "unweld" the ends of the pole instead (but that sort of "cheating" you know. ;-) /Mattias/
