Tue, Feb 18, 3:06 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: UVMapper
mark2 ( ) posted Fri, 10 November 2000 at 6:45 AM ยท edited Fri, 24 January 2025 at 11:32 AM
I use a program like uvmapper to change the texture (for example I want to have more control on the palms of the hands and so I decide to make them bigger). Than I change the file P4NudeWom.obj with the new obj file generated by UVmapper. But when I enter in Poser4, Poser4 still uses fot the woman the old type of obj file. I need help because I want to change the type of template used by Poser4. Can anyone help me? Thank you everybody.
Dave Wight ( ) posted Fri, 10 November 2000 at 8:13 AM
I think you need to delete (or rename, to be on the safe side) the big rsr file in the same directory as the obj file. Poser only uses the obj file to create the rsr, which it then uses to speed things up.
wyrwulf ( ) posted Fri, 10 November 2000 at 9:28 PM
There is no need to worry about deleting the geometries file RSRs. Poser will build a new one. It will just take longer for the figure to load when it does.
