Sun, Feb 16, 5:54 PM CST
Subject: Poser Error: Innsufficient Disk Space to Render at Current Resolution
insomniaworks ( ) posted Fri, 27 August 2004 at 12:11 PM · edited Tue, 04 February 2025 at 3:25 PM
I have been using PPP and P5 for some time on my old Pentium 2 computer with Windows 98 OS and never saw this message before. I commonly render at 2000 pixels. I have reciently purchased a Sony VAIO PCG-K23 Notebook PC (2.8 GHz Pentium 4, 512 MB RAM, 60 GB Hard Drive, Combo Drive). It has Windows XP Home OS. Now I am getting the error message while attempting to render alot! "Innsufficient Disk Space to Render at Current Resolution" By the way, I have lots of space on my hard drive. The hard drive was factory partitioned into a c: and d: drive. I have over 10 gigs available on the c: drive and much much more on the d: drive. Help! marty
xantor ( ) posted Fri, 27 August 2004 at 1:20 PM
If the C drive is nearly full then that is why the error comes up.
insomniaworks ( ) posted Fri, 27 August 2004 at 1:29 PM
I have 1.79 Gig left on my C drive I have 21.5 Gig left on my D drive Since I posted the last reply, I played with my virtual memory settings. But each time I changed something, Poser wouldn't work right at all. My virtual memeory settings are now set at "system managed size". Poser works well, but will not render many images of a specified size. Rendering to the windows always works.
insomniaworks ( ) posted Fri, 27 August 2004 at 1:32 PM
Virtual memory Total paging size for all drives 1340 mb
insomniaworks ( ) posted Fri, 27 August 2004 at 1:55 PM
Okay, I fixed this problem by moving a 1.5 from my C drive to my D drive. I have 3.39 gig free now on my C Drive. Its rendering now at all resolutions.
Bobbie_Boucher ( ) posted Fri, 27 August 2004 at 2:13 PM
When you're talking about graphics programs, 1.7-10GB is not very much. So therefore, your problem was(is?) the lack of hard drive space. As for the swap file, Curious Labs recommends adjusting your swap file settings. I found it easier just to get a much larger hard drive (currently 120GB), and reserve that for Poser alone. On the rare times that error occurs again, I defrag the hard drive. The problem is then solved. By the way, this question is asked and answered once or twice a week. You might find some great insights by doing a search or browse through the forum.
insomniaworks ( ) posted Fri, 27 August 2004 at 2:17 PM
I found that I could not exceed 2000 pixels width on my renders while experiementing. I cleared another gig off my C Drive and there was no change. Can someone tell me why I can not go past 2000 pixels width with out getting the error "Innsufficient Disk Space to Render at Current Resolution". I checked the Poser manual and it does not mention a size limit. thank you marty
insomniaworks ( ) posted Fri, 27 August 2004 at 2:37 PM
Thank you Bobbie, I did a search using key words listed in the subject and nothing came up before leaving this post. I think you answered my question pretty well anyway, thank you.
TygerCub ( ) posted Fri, 27 August 2004 at 4:38 PM
Just FYI... I found if my drive was anything close to 75% full, Poser started giving me this message. I think it's something to do with the way it uses the available free memory. It just needs a lot!
Bobbie_Boucher ( ) posted Fri, 27 August 2004 at 5:07 PM
Hmm, I just did a search on "Insufficient Disk Space," here in the Poser forum. Guess what I got? Seriously, you now know the answers.
geoegress ( ) posted Fri, 27 August 2004 at 5:44 PM
HI- in P5 reduce the bucket size and turn off back side polys will help a bit- but your problem really is your drive. You can find a 80 gig drive online for about 80 bucks. also- if you put poser on your d drive you'll get better performance (thank god all you have to do is cut and paste the program over :)
cake1 ( ) posted Fri, 27 August 2004 at 5:47 PM
Each time i get this message, when i still have space on HD, i do a defrag, and it renders fine again ;o)
judith ( ) posted Fri, 27 August 2004 at 8:44 PM
I've found it helps if you move your paging file off your main drive.
What we do in life, echoes in eternity.
E-mail | Renderosity Homepage | Renderosity Store | RDNA Store
elizabyte ( ) posted Fri, 27 August 2004 at 9:30 PM
I never got this problem fixed. I tried every possible suggestion, defragmented everything, messed with the virtual memory, upgraded the physical memory, rearranged the partitions, you name it. I eventually just upgraded to P5 (and I'm glad now that I did). Sorry to be so negative. I do wish you luck (some people really did find a way to fix the problem!). bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
cliff-dweller ( ) posted Sat, 28 August 2004 at 12:26 AM
I've found the CL's Poser Pro Pack Memory Updater fixes the problem for me on PPP: For Poser Pro Pack users with greater than 1GB of total memory (RAM + virtual memory = more than 1 GB.) to run normally. jen
Check out my full gallery at Cliff-Dweller Artworks
kristinf ( ) posted Sat, 28 August 2004 at 6:49 AM
I find that when I try and render at too high a resolution I get a similar problem. I have 4 gb of ram (3 shows up)so should really have a 10 gb pagefile or so but WindowsXP only recognises a 4 gb pagefile. Hopefully XP64 will address this (I use a dual opteron) but then I guess I will need to get a 64 bit poser and vue4pro to take advantage. In the end though I suspect the problem lies with Poser as I can move problem scenes that crash on Poser to Vue 4 Pro and then import more stuff and render it at very high res in superior or ultra mode without trouble. However, if Poser is loaded in the background it crashes :)
"I am extraordinarily patient, provided I get my own way in the end" - Margaret Thatcher 1989
svdl ( ) posted Sat, 28 August 2004 at 8:40 PM
I've seen this error pop up too, but only when rendering with the P4 render engine. My Poser is installed on my d: drive, with over 60 Gb of free space, defragmented. It happens both with small scenes (small in number of figures and props) and very large scenes. Usually Poser dies on the spot when the error pops up, after reboot the render usually works. It may have to do with Poser memory leaks.
My gallery   My freestuff
