Thu, Jan 30, 12:11 PM CST
Subject: Some ERROR :(
alexsm ( ) posted Thu, 02 September 2004 at 1:27 PM ยท edited Thu, 30 January 2025 at 11:57 AM
sodenly on one my project opening some error and it not oppening. What i can do to save this project ? if i can.
alexsm ( ) posted Thu, 02 September 2004 at 1:29 PM
this error :
GROINGRINDER ( ) posted Thu, 02 September 2004 at 2:24 PM
Defrag your hard drive!!
Rochr ( ) posted Thu, 02 September 2004 at 3:12 PM
I think some people here suggested that you try to open the temp-file. There was a thread not so long ago i think. This usually happen, when you get an error during saving.
Rudolf Herczog
Digital Artist
www.rochr.com
susanmoses ( ) posted Thu, 02 September 2004 at 4:35 PM
Sometimes this happens when a JPEG is used as a texture... but don't fret... everything will be saved from your last save (so save often, especially before you render)... you'll just have to recreate everything from that point onwards... Make sure to delete your AxiFFFe files that are created when this happens... as they consume hard drive space. And whatever you do... find another texture JPEG if this was the case. Cut your losses and close the file... something will be there when you open it again... but the generic error message will be gone. Sometimes right-clicking on the AxiFFFe file and renaming it '.br5' will take care of the problem... but not in my case. Good luck with this.
pakled ( ) posted Thu, 02 September 2004 at 4:49 PM
feh..these are annoying..it's like the 'engine' light on a Buick..something under the hoods' amiss, but I'm not going to tell you what..:|..good luck.
FrenchToast ( ) posted Thu, 02 September 2004 at 11:28 PM
heh... "Generic Failure" It just ... DIDN'T work.
pogmahone ( ) posted Fri, 03 September 2004 at 1:55 AM
gee.....I never knew that about jpeg textures! are BMPs better to use, then?
susanmoses ( ) posted Fri, 03 September 2004 at 2:07 AM
Most don't do it... but once in a while you get one that does. Kindof random.
Arianod ( ) posted Fri, 03 September 2004 at 12:48 PM
If you're using a jpg created in PaintShopPro, this can happen. If you take the jpg and run it through PSP's Optimizer (Save Copy As), it cleans this up. This only seems to occur with PSPv8 and v9, but not in PSPv7. lee
alexsm ( ) posted Sat, 04 September 2004 at 3:05 AM
I have not succeeded !
