Wed, Nov 27, 5:15 AM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: how do i get poser animations into bryce?
charlietbuket ( ) posted Fri, 20 October 2000 at 4:26 PM · edited Wed, 13 November 2024 at 9:14 AM
i need to get my poser animations into my bryce animations. can anyone please help me?
EdW ( ) posted Sat, 21 October 2000 at 4:44 PM
Right now the only way to do this is to export sequenced meshes from Poser and import them into Bryce. It's a long process. Ed
cliffwms ( ) posted Mon, 30 October 2000 at 12:10 PM
Just a suggestion. This may not be the forums approved method, but for quick dirty methods, I blue screened my animated Poser characters and then composited the Bryce image using Premiere. I was able to get away with using this technique when some secenes were not critical and I did not have to be concerned with ground shadows and detail alignment. Cliff
Shadowrogue ( ) posted Mon, 13 November 2000 at 7:04 AM
So, if I understand this right, I then import each different Poser mesh into my Bryce file at the same corresponding second (i.e. Poser mesh from second 3 of Poser animation to Bryce file at second 3 of Bryce animation file), replacing the previously imported Poser file? I just want to make sure I have this right before I start the timely process. ;) Thanks, Ed!!! Mike
doctorkoan ( ) posted Mon, 13 November 2000 at 2:20 PM
Another work around, depending on your situation, might be to render your bryce animation first, then import it into poser before setting up the poser animation. I know this works on the Mac. If you judiciously stroyboard ahead of time it would make this technique easier. The advantage to this is that you can set up keyframes right over the Bryce movie, making synching a little easier. Now if you Have to have the character(s) walk behind a brycy object, you will need to import that object into Poser, which might be problematic depending on the situation. In that case you could do a seperate Bryce animation with the solo renderer and use Premier to composite it after the initial Bryce movie in Poser rendering.
EdW ( ) posted Mon, 13 November 2000 at 8:30 PM
You need to set your Bryce animation to the same number of frames per second. Poser will export a mesh from each frame for the character(s). If your animation in Poser is say 30 frames you will end up with 30 sequenced meshes starting at 001 to 030. You then need to import each mesh into Bryce and position the mesh, add the textures, etc . That's what I mean by a long hard process. Ed
Shadowrogue ( ) posted Mon, 13 November 2000 at 9:21 PM
Cool, that's what I understood, I just wanted to make sure. Hey, thanks alot for the help!!! ;) -Mike
EdW ( ) posted Tue, 14 November 2000 at 1:05 AM
Glad I could help. Make sure you post the animation when it's finished.. I would like to see it. Ed
