Wed, Dec 25, 1:12 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: C4 SDK
gavotte ( ) posted Sat, 04 September 2004 at 9:33 PM · edited Fri, 08 November 2024 at 4:43 AM
Does anyone know if / when the C4 SDK will be available? I am just getting started with the C3 SDK and am wondering if I should simply plunge ahead and hope that the experience I pick up will carry over, or would I be better off simply waiting?
mdesmarais ( ) posted Sun, 05 September 2004 at 7:14 AM
Plunge away. Unless there is a radical departure from the past, porting is pretty quick and easy. Not only the experience will carry over, the code will too. I was told that it is not ready yet, and that they are working on it as fast as they can. No date given. Regardless, you have at least a month, as the SDK does you no good at all until you have the program. ;-) Also, if you plan on supporting CS3, you will need to work to that SDK as well (you need to do each version as a separate compile). Markd
