Attached Link: http://www.darrinsden.com
okay, I might be able to help here :) there are two things that did that to me... 1) I have a nvidia vidio card and some of the beta drivers caused that behavior, going back to the previous driver fixed the problem... if you havent changed video drivers, it might be a corrupted file in the poser directory... what it was for me was the fact that I used to install all my poser utilities under that directory and something was causing a messup... Change the directory name, and reinstall poser, then start moving things back in.. start with the geometries and libraries and then check to see if things are still working correctly, and at each stage check so you can see what might cause the problem.. DarrinThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
hi iam running poser on win2k and it has been working fine, but all of a sudden when i start it up, before it shows the title and credits it quits out, meaning when I start up the prog by clicking on the exe I see the window for about 3 seconds then it quits out. I dont know what could be causing it but its really agrrivating. I also tried reinstalling and it does the same thing.
