Sun, Jan 12, 2:59 PM CST
Subject: Getting Rid of Full Body Morphs
mask2 ( ) posted Sat, 11 September 2004 at 12:30 PM · edited Wed, 25 December 2024 at 1:54 PM
Hello, I am very new to Poser and I was practising about how to create Body Part Morphs and Full Body Morphs. I noticed I can erase Body Part Morphs very easily by right clicking on the small arrow on the right side of the dial in the parameter dial palette... However, the same "delete" option is grayed out for Full Body Morphs, even if the dial it's zeroed. How to get rid of Full Body Morphs once created? Thanks in advance for Your replies! Mario
Teyon ( ) posted Sat, 11 September 2004 at 2:29 PM
I'm going to move this to the Poser forum. I think you'll have better luck there.
mask2 ( ) posted Sat, 11 September 2004 at 5:18 PM
:-) Thanks!
TrekkieGrrrl ( ) posted Sat, 11 September 2004 at 7:01 PM
You can't delete a Full Body Morph because it's not really there. A fbm only tells Poser than any morph on the character with the same name as the fbm (for instance Muscular1) should be applied simultanously. So you can delete all occurences of Muscular1 but the fbm will remain. You'll have to hack the CR2 then. Hope that helps :o) ~TrekkieGrrrl
SWAMP ( ) posted Sat, 11 September 2004 at 7:20 PM
You can also use the free MorphManager to delete the Body morphs dials from the cr2. Just laoding a cr2 in MM won't show the Body morphs,but.... If you load a pz2 (any pz2 will due) first,and then load the cr2,the Body morphs now show,and you can delete away. SWAMP
TrekkieGrrrl ( ) posted Sun, 12 September 2004 at 3:06 AM
Ah you're right, SWAMP. I forgot about that pz2 - cr2 trick in Morph Manager :o) Thanks for reminding me :o)
Gareee ( ) posted Sun, 12 September 2004 at 8:34 AM
Actually, you can delete a fbm in poser 5.. open the hierchy editor, select the fbm, and hit "delete" Might work in P4, but I'm not sure...
mask2 ( ) posted Sun, 12 September 2004 at 10:35 AM
Thanks for Your time guys: problem solved!
