Sat, Nov 9, 5:18 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 3:34 pm)
Subject: Object import problem
xantor ( ) posted Mon, 13 September 2004 at 9:56 AM ยท edited Fri, 02 August 2024 at 11:05 PM
I imported this ufo object into poser and it had this extra square appear at one of the windows, it is not a polygon, does anyone know how to fix it?
xantor ( ) posted Mon, 13 September 2004 at 10:26 AM
The object has already been through uvmapper, I used that to split the vertices because the object had the "all rounded edges" thing when it was first imported into poser. I have tried a few different things to fix it and it still happens.
jupiterkris ( ) posted Mon, 13 September 2004 at 11:00 AM
It is likely a twisted face . If so, the only way is to excise it . Split the object, keep the working half, mirror and weld . You could use negative scale and flip to mirror, then export and import back with weld .
xantor ( ) posted Mon, 13 September 2004 at 11:42 AM
It isnt a face, the object isnt mine so I don`t want to chop it up to try and get it to work, thanks anyway.
