Attached Link: http://gray.ballarat.net.au/cgi-bin/make_waves.pl
His program generates the same terrain map unless you want to play around with his settings. But he gives you the gray scale map itself at the link in his tutorial. It's the one I posted on top of this message. Download the map, save it and load it into the terrain editor. You don't actually run the perl script in Bryce, just use the image it created.It says right there- "You cannot cut and past it as bryce doesnt understand png (portable network graphic) format graphic files"... You have to convert the png into a bitmap. Do you have an image editor such as PhotoShop or PSP? If not, Google for Irfanview. It is a very useful app and will convert almost any image file from one format to another.
Sorry when I click on the link using IE it creates a png image for me. I save this as a bmp image somewhere on my hard drive and then load the image into the terrain editor in Bryce. There are dozens of paintshop, photoshop, or other drawing programs that can make the same image dozens of ways. Maybe you could tell us if you have an image drawing program then one of us can give a better answer.
Message edited on: 09/15/2004 15:12
Attached Link: http://www.bsmooth.de/BSolutions/#TerrainEditor
Here is a nice tutorial that shows how to setup photoshop as a plugin for the Bryce terrain editor.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Attached Link: http://gray.ballarat.net.au/bryce/tutes/sea_foam/
Hi guys, I was looking at someone's tutorial (see link) and he mentions running a Perl script on a terrain to create waves. He supplies the script but doesn't mention how to use it. I've never run a perl script in Bryce before and I was wondering if anyone knew how to do it? I'd really appreciate any help.
