Wed, Jan 22, 3:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 12:55 am)
Subject: Part of a model not displaying..
Shaddex ( ) posted Sat, 18 September 2004 at 3:29 AM ยท edited Wed, 22 January 2025 at 1:40 AM
I just got the Antelope Expansion Pak from DAZ, and have everything for it, but when I looad it in poser, only the horns display. I also have a deer set that uses the zygote buck, I have that buck, and when I loaded the deer set it asked to be told where the model was, and I told it where it was in the Geometries folder, but I got the same prob, the bodys missing, and just the horns show up. So umm.. HOW do I fix this? :/
jupiterkris ( ) posted Sat, 18 September 2004 at 5:56 AM
The rsr file might be corrupt . Go to the Geometries folder containing the models . Delete the ".rsr" file - eg buck.rsr . A new one will be generated when you reload the character . Hopefully this will fix it .
nickedshield ( ) posted Sat, 18 September 2004 at 9:24 AM
If you are being asked to find an .obj, look at the cr2 file, figureres line and check the path, then check to see if your folders match.
casey_42 ( ) posted Sat, 18 September 2004 at 9:31 AM
Is it posible that the expansion pak might only be horns and texture and that the body and head might need to be in the original?
Shaddex ( ) posted Sat, 18 September 2004 at 10:49 AM
Nope cause where the body should be theres that X shaped thingy. So I know for a fact it IS to have the full animal. Thats why I baught it. It dose come with horn props but it also has the animals, but the body don't want to display. And the Buck displays just fine, it's the other Deer models that requier it that don't want to display as well as the Antelope Expansion Pak.
