Thu, Jan 23, 8:13 AM CST
Subject: Changing cr2 to different obj leaves missing groups? HELP!
7/8'sIrish ( ) posted Sun, 19 September 2004 at 3:13 AM ยท edited Thu, 07 November 2024 at 8:43 PM
Hi, I changed the shape of the mesh in some groups, (also adding some polygons to those few groups) to a custom creature in my modeler. The group names stayed the same. I redirected the cr2 to the changed file. But when I opened the figure from the libraries palete some of the newly changed groups are missing? When I check the cr2 the missing groups are not in there? What is the work around for this? Thanks
n0s4ra2 ( ) posted Sun, 19 September 2004 at 4:53 AM
Ok. Poser loaded the bones. But did not load the groups for those bones. Why? Because you renamed the groups. Bones and groups must be named the same. Import your new model. Then go to setup tab. Then click and load the old cr2 file and the bones will re load. Now rename the bones to mach the new group name. Or rename the group to match the bones.
7/8'sIrish ( ) posted Sun, 19 September 2004 at 6:04 AM
Yeah thanks you are so right
