Thu, Jan 23, 12:24 PM CST
Subject: Can you copy joint parameters from one figure to another figure?
7/8'sIrish ( ) posted Sun, 19 September 2004 at 3:43 AM · edited Thu, 23 January 2025 at 8:11 AM
Hi, Can you copy joint parameters from one figure to another figure? Or just some selected joint parameters to another figure? Thanks
n0s4ra2 ( ) posted Sun, 19 September 2004 at 4:57 AM
You can Load the figure then go to setup. Then while there load the figure you want the bones from. Notice the bones are overridden. If the groups and bones are name the same. Then it will bend. But you will have to do some joint tweaking.
7/8'sIrish ( ) posted Sun, 19 September 2004 at 6:05 AM
cool
xantor ( ) posted Sun, 19 September 2004 at 9:54 AM
That is the way that I usually bone my figures. I start off with the poser 4 figure bones and sometimes delete some or add some where required. The use of bones from the poser 4 figures at least is allowed (probably NOT the daz ones though).
7/8'sIrish ( ) posted Sun, 19 September 2004 at 2:30 PM
okay thanks for the info
Cage ( ) posted Mon, 20 September 2004 at 1:11 AM
Hi, Can you copy joint parameters from one figure to another figure? Or just some selected joint parameters to another figure? Thanks You can also hack the .cr2 and build a JP injection pose. They are quick and easy, once you get the hang of them.
7/8'sIrish ( ) posted Mon, 20 September 2004 at 2:00 AM
cool please explain in easy to follow detail Thanks
