Thu, Jan 9, 9:39 AM CST
Subject: Firefly renderer and Focal length
pixelsquash ( ) posted Mon, 20 September 2004 at 12:38 AM ยท edited Wed, 08 January 2025 at 9:18 PM
Hi, I'm trying to render a scene which uses a very low focal length (10mm) to catch a wide area and make the scene look more surreal. However I'm trying to use the firefly renderer in Poser but parts from the scenes objects always get cut off at the borders. There is a table that reaches beyond the frame borders and edges from the table are not being rendered. This doesn't happen with the poser classic renderer but this also has inferior quality. Any solutions?
www.renderosity.com/mod/gallery/browse.php
richardson ( ) posted Mon, 20 September 2004 at 1:30 AM
Make sure your work window is the same proportion as your renderwindow. any variation will crop the end result one way or the other... If I'm missreading you post a sceenshot...
pixelsquash ( ) posted Mon, 20 September 2004 at 2:24 AM
Ok, here's a picture of the problem... http://upload.corewatch.net/pics/Pool_Scene_Test2.jpg No, it's not a photographic edge effect from Pogotoshop! ;] If there's no way to get around it at a very small focal lengths I would import the scene into Vue and render it there. But if I import the scene into Vue, all objects are reset to their initial position. Would be great to know how to get that working too.
pixelsquash ( ) posted Mon, 20 September 2004 at 2:25 AM
Attached Link: http://upload.corewatch.net/pics/Pool_Scene_Test2.jpg
hm link in text doesn't work, so here again....
ynsaen ( ) posted Mon, 20 September 2004 at 6:33 AM
In general, this will occurr with ANY focal length of less than 20mm, and is a known limitation.
pixelsquash ( ) posted Mon, 20 September 2004 at 6:36 AM
Ok, solved the prob by choosing another perspective with a 20mm lens. Thanks for helping!
xantor ( ) posted Mon, 20 September 2004 at 8:36 AM
Can`t this be fixed by playing about with the hither camera parameter? I would give that a try.
richardson ( ) posted Mon, 20 September 2004 at 10:30 AM
Do a search on ronstuff. He solved a lot of things I was working on by increasing the whole scene 500-1000%. Future refs anyway.
