I've encountered this problem. I reinstalled Poser (and re did the 4.03 patch) to fix it. This will not over write your custom files provided that they do not have file names that come with the original program. In the unlikely event that the KERNET32.DLL is corrupted it may be replaced by downloading it from the web, www.microsoft.com would be a good place to start searching. Hope this helps, Regards
Hi, I'm not a PC admin, but having asked those who are, the only advice about replacing the Kernel of the operating system, (the beating heart of NT, if such could be said to exist) the only advice I could get, (other than "DONT!") was "you'd better do it from a DOS session" which means you'd need to boot NTFS offline, which is no easy task, I have a tool for doing it, if you really need to, and I could tell you the name of it, but you'd really have to know what you were doing to even think about using it, (not to mention fully backing your system up first...) because if you replace it and it doesn;t take, you've killed the OS, a complete re-install is your only choice. If you're doing it from 98, (and there seems to some confusion about whether 98 has one) then it should be easier, just boot from a DOS floppy, but again, if you replace it and it doesn't take, you've shagged your box, "bring out your dead..." and re-install. It's basically a very, very, bad idea, that a sane admin would only try if he had no backup and no other choice. later jb
![file_137727.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_137727.jpg)
For some strange reason, I can't inport any kind of objects except DXF files into Poser! Whenever I try, it gives me this error. Look at the circled dll file. Maybe if I replace it with a new one will work, but I need someone to send it to me! If anyone wants to do it, send it to vgueorguiev@cfl.rr.com Thnak You! -Emo
