Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
If you add David then remove all ik and zero the figure, then add the m3 clothes and scale till it allmost fits, then use the joints of the clothing to try and improve the fit (never move any David joints) then fix any poke through with magnets.....once it fits delete david and export as obj, now on the last window you get (can't remember what its called but its the one with things like, include body group names, and the like) check ONLY the top box.......you now have an obj ready to plug into a cr2, so use a David cloth cr2 to swap the geometry with or use something like PWizard to create a cr2........Steve
I used the Clothes Converter and it works, but the problem is that your end result is a cr2 with no JCM and so you will have a lot of poke troughs. Do you know how to save a pose that only chang Joint settings? I wanted to try and scale and reposition a cloth and save it to the library for a different character, export the object and repoint to the new cr2 and apply the joint setting pose os say a david cloth to a M3 cloth. this should keep all the morphs of the original cloth working. would it work?
Attached Link: http://arcana.daz3d.com/index.php?id=72
Staby, there's a tut at the link which shows how to make a JP pose."you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Pls can david Cloths work for M3 and can M3's cloths work for David ?
