Sun, Feb 2, 10:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: MalePoseAmation
Methastopholis ( ) posted Wed, 29 September 2004 at 1:48 AM · edited Sun, 02 February 2025 at 8:08 PM
Can someone just tell me what to do .cus i dont think ill have any hair left by morning .if i keep at this. Or im just stuck on stupid . any way i have thew MalePoseAmation set with pz2 & bvh files in im sure some of you are familiar with this set. in the instruction's it say i can edit the bvh file's so that they work with Mil chracters. Ok i did a forum search and read bout 5 or 6 pages and gave up. so im just gonna ask none of you wonderful eeps to do it 4 Me please. here the instruction's it has : : :Installation Instructions: BVH files are not platform dependant so they can be used on PC or Mac with no conversion necessary. All of these files have the arms aligned along the X axis. When using Poser, select the figure that you want the action applied to, then chose File: Import: BVH Motion. Be sure that you have the FIGURE and not clothing or a prop selected when applying the action. You will then be asked which way the arms are aligned, choose X-axis. BVH files don't contain any morph target information so no facial animation will be included. If you are applying these actions to a figure that uses a different set of naming conventions for body parts than the standard Poser figures, certain body parts will be ignored and will not receive any motion information. You can edit the BVH file in a text editor to make the references to body parts suit the conventions of your figure. It will take a little effort but it will be quicker than trying to animate it yourself! :') so here a BVH file 1 arm sword swing and here the bvh in text can some one show me what to add or change this bvh so it will work for M3. and if possble highlight the addition or changes made ? : HIERARCHY ROOT hip { OFFSET 0.00 0.00 0.00 CHANNELS 6 Xposition Yposition Zposition Xrotation Zrotation Yrotation JOINT abdomen { OFFSET 0.039181 5.637571 0.560720 CHANNELS 3 Xrotation Zrotation Yrotation JOINT chest { OFFSET -0.136063 7.190206 -0.124363 CHANNELS 3 Xrotation Zrotation Yrotation JOINT neck { OFFSET 0.193764 10.560151 -1.259468 CHANNELS 3 Xrotation Zrotation Yrotation JOINT head { OFFSET -0.096882 0.362727 0.622109 CHANNELS 3 Xrotation Zrotation Yrotation JOINT leftEye { OFFSET 1.356350 5.062672 4.221998 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 0.000000 0.000000 0.871939 } } JOINT rightEye { OFFSET -1.356350 5.062672 4.221998 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 0.000000 0.000000 0.871939 } } } } JOINT rCollar { OFFSET -3.778404 4.940989 0.193764 CHANNELS 3 Yrotation Zrotation Xrotation JOINT rShldr { OFFSET -2.615818 1.356350 -0.484411 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rForeArm { OFFSET -11.432094 0.484410 -1.937643 CHANNELS 3 Yrotation Zrotation Xrotation JOINT rHand { OFFSET -10.657035 -0.096881 0.581293 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rThumb1 { OFFSET -0.678175 -0.581297 0.968821 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rThumb2 { OFFSET -0.968823 -0.484410 0.484411 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rThumb3 { OFFSET -0.929680 -0.497680 0.055639 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET -1.097191 -0.513867 -0.001182 } } } } JOINT rIndex1 { OFFSET -3.003348 0.581291 1.259468 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rIndex2 { OFFSET -1.468152 -0.266718 0.069755 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rIndex3 { OFFSET -0.944212 -0.382684 -0.083028 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET -0.675657 -0.558718 0.000000 } } } } JOINT rMid1 { OFFSET -3.197113 0.581291 0.290646 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rMid2 { OFFSET -1.550115 -0.387529 0.000000 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rMid3 { OFFSET -0.731071 -0.803926 0.018214 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET -0.366992 -0.937043 0.083406 } } } } JOINT rRing1 { OFFSET -3.197113 0.387529 -0.678175 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rRing2 { OFFSET -1.259466 -0.484410 0.096882 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rRing3 { OFFSET -0.551552 -0.801218 0.111221 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET -0.245208 -0.810324 0.000000 } } } } JOINT rPinky1 { OFFSET -2.809584 -0.096881 -1.453232 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rPinky2 { OFFSET -0.984323 -0.316034 0.039140 CHANNELS 3 Zrotation Yrotation Xrotation JOINT rPinky3 { OFFSET -0.468908 -0.555906 0.057742 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET -0.479664 -0.640198 0.044081 } } } } JOINT swordfin.OBJ_1 { OFFSET 28.580233 -59.098112 2.518936 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 29.064646 29.064646 0.000000 } } } } } } JOINT lCollar { OFFSET 3.972168 4.940989 0.193764 CHANNELS 3 Yrotation Zrotation Xrotation JOINT lShldr { OFFSET 2.615818 1.356350 -0.484411 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lForeArm { OFFSET 11.432094 0.484410 -1.937643 CHANNELS 3 Yrotation Zrotation Xrotation JOINT lHand { OFFSET 10.657035 -0.096881 0.581293 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lThumb1 { OFFSET 0.678175 -0.581297 0.968821 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lThumb2 { OFFSET 0.968823 -0.484410 0.484411 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lThumb3 { OFFSET 0.929680 -0.497680 0.055639 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 1.097191 -0.513867 -0.001182 } } } } JOINT lIndex1 { OFFSET 3.003348 0.581291 1.259468 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lIndex2 { OFFSET 1.468152 -0.266718 0.069755 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lIndex3 { OFFSET 0.944212 -0.382684 -0.083028 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 0.675657 -0.558718 0.000000 } } } } JOINT lMid1 { OFFSET 3.197113 0.581291 0.290646 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lMid2 { OFFSET 1.550115 -0.387529 0.000000 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lMid3 { OFFSET 0.731071 -0.803926 0.018214 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 0.366992 -0.937043 0.083406 } } } } JOINT lRing1 { OFFSET 3.197113 0.387529 -0.678175 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lRing2 { OFFSET 1.259466 -0.484410 0.096882 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lRing3 { OFFSET 0.551552 -0.801218 0.111221 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 0.245208 -0.810324 0.000000 } } } } JOINT lPinky1 { OFFSET 2.809584 -0.096881 -1.453232 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lPinky2 { OFFSET 0.984323 -0.316034 0.039140 CHANNELS 3 Zrotation Yrotation Xrotation JOINT lPinky3 { OFFSET 0.468908 -0.555906 0.057742 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 0.479664 -0.640198 0.044081 } } } } } JOINT shield.OBJ_1 { OFFSET -17.923198 -59.194993 3.100229 CHANNELS 3 Zrotation Yrotation Xrotation End Site { OFFSET 29.064646 29.064646 0.000000 } } } } } } } JOINT rThigh { OFFSET -3.875286 0.717509 0.339475 CHANNELS 3 Xrotation Zrotation Yrotation JOINT rShin { OFFSET -0.434323 -20.673392 0.003424 CHANNELS 3 Xrotation Zrotation Yrotation JOINT rFoot { OFFSET -0.063555 -15.653578 -0.075717 CHANNELS 3 Xrotation Yrotation Zrotation JOINT rToe { OFFSET -0.513669 -2.790361 5.061637 CHANNELS 3 Xrotation Yrotation Zrotation End Site { OFFSET 0.000000 -0.280183 2.993164 } } } } } JOINT lThigh { OFFSET 3.875286 0.717509 0.339475 CHANNELS 3 Xrotation Zrotation Yrotation JOINT lShin { OFFSET 0.434323 -20.673392 0.003424 CHANNELS 3 Xrotation Zrotation Yrotation JOINT lFoot { OFFSET 0.063555 -15.653578 -0.075717 CHANNELS 3 Xrotation Yrotation Zrotation JOINT lToe { OFFSET 0.513669 -2.874842 4.946725 CHANNELS 3 Xrotation Yrotation Zrotation End Site { OFFSET 0.000000 -0.195702 3.108076 } } } } } JOINT genital { OFFSET 0.000000 -2.285840 3.439704 CHANNELS 3 Xrotation Zrotation Yrotation End Site { OFFSET 0.000000 -3.996001 0.087581 } } } MOTION Frames: 10 Frame Time: 0.100000 -0.653253 36.825653 10.604236 -4.910550 -0.346243 -21.079599 -11.289500 2.944030 3.758600 24.570700 -5.177400 7.548220 1.291220 -0.309682 0.855960 7.553490 -0.278740 0.684593 -0.214176 -0.684631 -15.101500 -0.111325 0.784490 -16.151699 16.829800 10.521300 2.007110 52.833302 11.424400 11.542200 41.943699 2.636540 -1.243120 26.054501 8.868590 -13.215200 -7.090785 0.674392 19.093060 -3.344530 18.767809 -7.137723 -38.545139 -45.290306 24.829279 37.423599 -6.664760 4.629580 51.310223 -7.557714 2.741427 43.057789 -3.978409 3.009593 61.992790 3.297491 14.867387 51.694679 -4.135363 4.955362 29.862431 -13.498265 15.908926 51.069294 10.252941 14.516071 51.269627 10.277334 12.838130 42.653454 24.703621 12.768405 7.692682 23.061653 3.257159 73.778908 6.271980 12.348283 54.112179 -0.315710 4.744758 -14.075600 -4.129310 -99.888702 12.169400 -8.462260 1.487010 -57.040501 -0.049792 -4.746330 -58.769402 -4.544300 -6.556470 -25.156700 -8.756410 -0.153606 -7.984824 -11.211831 13.028322 -2.397929 -3.102569 1.297954 28.039146 33.211147 9.031853 -38.104401 6.743600 0.072719 -78.181282 1.492716 -4.882209 -74.370735 2.019646 -1.172399 -73.119217 -2.105977 -0.978350 -77.752945 -0.996112 -2.270259 -4.806540 11.645254 -5.146205 -82.845673 -3.407219 -0.716007 -49.330139 -8.602364 5.271786 -29.904860 -20.968960 13.518321 -65.818390 -4.202289 -11.464670 -73.243767 -5.344917 6.888686 -30.291742 0.637707 2.566456 -21.893600 158.802994 -187.800003 7.909606 -21.444452 -13.113247 4.141873 -0.704978 -6.004663 -3.371220 14.129148 8.789834 -0.019858 -1.095080 8.019430 6.645036 10.500870 5.831223 6.617055 3.660187 0.757913 -9.188515 14.361482 -15.248855 -0.701626 -0.045792 -0.003026 0.000000 -0.175740 -0.004391 -0.564486 36.960617 11.109088 -2.102010 -7.082270 -12.896600 -11.449500 10.711800 6.849990 21.526400 -1.627600 8.672920 0.236376 -0.210012 0.421179 15.612600 4.269630 0.939548 0.699503 -10.782800 -15.946000 1.107510 -11.490800 -18.914700 36.727798 -11.721800 -18.912399 58.832901 2.887770 -21.499300 60.946301 1.932840 -27.498699 -3.828640 -16.266701 -1.248070 -9.115497 -1.078465 20.733044 -3.238283 18.339926 -6.812220 -38.519421 -44.883575 23.809956 35.035702 -9.724130 4.777660 50.755035 -7.726342 2.991703 43.590767 -3.576173 3.881695 58.606262 0.774309 14.979565 52.385422 -3.262459 4.226470 29.585405 -12.730233 17.140057 51.039974 6.503740 13.748404 47.930092 9.961290 13.670736 44.424141 25.303350 13.610988 6.490636 20.599859 4.849068 72.910141 6.137130 12.635067 54.499615 0.433221 4.912232 -14.075600 -4.129310 -99.888702 23.904499 -9.661240 -0.252247 -60.502102 -7.237920 13.900600 -48.542099 -4.372510 -8.842290 -23.946699 -9.515720 -0.795416 -8.921733 -10.801275 14.465992 -2.965759 -3.485232 0.557364 29.461424 33.252838 10.040942 -37.062698 7.276730 0.686743 -79.600861 1.801487 -4.988168 -75.069061 2.736614 -1.296890 -74.012726 -0.900630 -0.543405 -77.752090 -0.857942 -1.837365 -3.580515 11.592762 -5.568225 -82.463432 -2.330049 -0.588246 -49.976704 -8.757571 4.338668 -30.133501 -19.915010 13.870427 -65.189102 -2.672287 -11.049543 -74.129242 -5.027452 7.179039 -29.293110 0.153451 2.139588 -21.893600 158.802994 -187.800003 -4.134593 -12.431238 -9.846256 29.988779 -10.685939 -9.557405 -4.321888 18.143652 9.594638 0.157503 -0.657140 5.765130 -10.601250 19.795513 22.928305 34.328613 15.456255 5.494138 -13.746325 -14.568983 -22.154654 -0.878860 0.009007 0.000609 0.000015 -0.175740 -0.004391 -0.086522 37.414093 12.764707 7.230680 -21.193300 33.913502 -10.012100 11.024800 4.842670 -0.934321 8.149150 0.932290 12.496300 1.992310 -0.162382 12.770200 21.631001 -20.377600 0.749620 -42.429401 -11.212000 -0.702493 -40.273399 -18.708000 54.574699 -60.437901 -11.622000 60.981998 7.530160 -52.390499 60.603001 0.638457 -43.609501 -4.206450 9.680490 -0.328410 -9.277941 2.093817 19.625553 -3.711355 19.046236 -7.338947 -39.244240 -45.943077 25.867451 35.179001 -6.805110 5.482020 50.661777 -7.248425 3.188399 43.503830 -4.503573 3.327527 59.112473 3.115371 16.410954 51.294144 -4.391926 5.070153 30.380709 -12.657599 16.933651 49.580849 10.000464 16.076508 50.236271 10.516646 13.160191 42.108437 25.827202 12.467712 6.030606 24.170050 4.693276 72.936012 7.113388 11.988667 55.133610 -0.524341 5.214424 -14.075600 -4.129310 -99.888702 18.903799 -8.144300 -0.388769 -65.299500 -4.240620 25.424500 -69.121399 -3.978460 -11.836250 -23.666901 -10.684600 -0.236334 -9.001990 -11.302593 14.087360 -2.437288 -2.373482 0.495864 28.902218 32.980118 9.135177 -37.777699 6.304850 0.651297 -78.816681 1.413841 -6.064818 -75.410133 2.430326 -0.749846 -73.999504 -1.945991 -1.169851 -77.762856 -0.580862 -2.207622 -3.666013 12.032320 -5.861492 -82.858788 -3.058768 -0.988140 -49.527302 -8.762516 5.944703 -29.912825 -20.497528 12.235415 -65.314301 -4.047963 -11.730405 -73.420547 -5.034379 6.250635 -29.779966 0.669988 2.354766 -21.893600 158.802994 -187.800003 5.515738 4.735348 -31.453854 1.486670 -1.076081 -2.163191 26.759584 -17.166008 20.428108 0.576488 -0.684741 7.882040 -51.712578 23.637894 22.436144 47.953197 6.899935 4.328983 0.513906 -34.328941 -4.231083 -14.549700 0.662276 0.396988 0.000984 -0.007713 0.351451 0.091384 32.536213 13.429222 5.097790 -13.315300 20.631701 -8.267690 4.603000 61.404202 14.668200 8.260380 25.174700 -13.714300 3.376470 -14.443400 -7.329830 26.534700 -61.378101 0.476357 -32.269798 -14.290900 0.702094 -39.710800 -22.888300 42.943298 -45.620201 -8.845000 29.692801 19.756001 -54.862400 89.136101 0.333726 14.886200 9.105870 5.066810 -2.904770 -9.439697 2.014545 20.515299 -3.563629 18.443758 -6.573229 -38.479000 -45.439590 24.709036 35.031399 -7.783870 6.887860 50.226135 -6.524212 3.147176 43.391453 -4.119329 3.039693 59.319332 1.770957 17.294277 51.102036 -3.393715 4.666933 29.515936 -12.743698 16.912628 49.498188 8.832014 16.789339 50.047615 10.308771 13.079869 42.800388 26.052946 13.317572 6.500935 23.799891 5.858185 72.944984 6.749902 12.490558 54.820187 0.045981 5.104338 -14.075600 -4.129310 -99.888702 -40.052299 -30.533600 4.709040 -20.612000 -17.840300 -20.994400 -91.735001 -1.430720 -14.704391 -24.462900 -10.779400 -0.965737 -8.920621 -11.037024 13.965954 -2.694719 -2.554351 1.013405 28.826471 32.927593 9.341829 -37.937500 7.402100 0.651651 -79.217186 1.338565 -5.229483 -74.543739 2.283439 -1.167524 -73.838539 -0.691911 -1.092926 -77.780373 -0.172357 -2.138070 -3.687200 11.450047 -4.945896 -83.041771 -2.111987 -1.167157 -49.156338 -8.608874 5.419492 -30.817219 -20.733421 13.850564 -65.020447 -2.845292 -11.323672 -74.292961 -5.823148 5.857734 -29.312149 1.402463 3.145635 -21.893600 158.802994 -187.800003 -25.136673 -12.484048 -19.591476 81.215118 -12.400720 -3.124321 3.088140 -5.838377 6.907039 0.206879 -0.798579 7.695770 -52.734970 27.071133 17.875584 77.442253 4.101508 7.838323 -18.601665 -5.489507 4.487347 0.000660 -0.032144 0.526459 0.000000 0.000000 0.000000 -1.344627 30.136608 13.923903 -10.255300 -7.154450 10.476700 14.070700 8.678240 45.072102 39.593399 -2.811210 17.368799 -22.100201 1.919820 1.380790 -6.346250 21.514999 -58.491001 0.163634 -22.683701 -16.952101 0.656020 -31.528799 -20.807301 16.446400 27.616600 0.593875 -97.810402 49.072201 -74.462502 59.774799 0.099124 -0.258060 -5.294010 -16.008699 0.636060 -9.302132 -0.119944 21.588150 -3.345826 18.463850 -6.946940 -38.828438 -45.197975 25.163416 34.668701 -10.291900 4.892270 50.704319 -8.151168 3.451647 43.546394 -3.854629 4.142438 58.412319 0.224027 15.313554 52.262070 -4.087583 4.555564 29.875137 -12.672379 17.047915 51.239441 6.785285 14.904763 47.900009 9.771213 13.211741 43.209335 26.045124 12.992532 6.636044 20.870340 5.916763 72.924690 6.492005 12.557895 55.139832 -0.295632 5.270260 -14.075600 -4.129310 -99.888702 -39.583099 -31.314699 3.665860 -40.143600 -21.613001 -63.459900 -123.186996 -2.969410 -16.560801 -23.922600 -10.539200 -0.927298 -8.477686 -10.888353 14.611957 -2.382781 -2.258751 0.747484 28.251472 33.149261 8.770166 -36.718201 7.197460 0.704667 -79.709114 1.171014 -5.654450 -75.251320 2.242840 -1.316435 -73.485344 -1.342692 -1.288729 -77.251717 -0.396638 -2.341662 -4.014819 11.096897 -5.725019 -82.472183 -2.493302 -0.682695 -49.484272 -8.404290 4.478667 -30.485270 -21.182665 14.480870 -64.514832 -2.895521 -11.662187 -74.122299 -6.119890 6.197863 -29.726236 1.648970 2.480383 -21.893600 158.802994 -187.800003 -21.193584 -10.721875 -14.466899 101.769295 -15.887480 -11.364657 15.400376 -2.842935 0.402983 -9.463220 -0.657261 5.933960 -35.976292 34.580563 18.787889 87.824280 9.606919 -4.206886 -22.261175 0.212038 -3.702488 -0.672238 0.788936 0.404717 -0.124695 -0.123867 -0.002850 -4.240483 31.439169 9.085801 8.545320 -12.098600 -30.623800 21.428900 -14.161200 32.527699 6.383180 -4.254450 47.602501 -27.720501 -6.602550 -28.522499 15.453900 6.314140 -15.039400 0.061661 -25.290501 -13.448500 0.419817 -30.287300 -16.802401 29.558399 -8.269810 -9.996700 19.868500 35.249802 9.326310 20.783501 -0.378706 6.009900 -4.616240 -39.492699 -1.092140 -9.627679 -0.921520 22.218311 -3.610166 18.973528 -7.109278 -38.893761 -45.045620 25.779245 35.343899 -11.017800 5.095200 50.089466 -7.626244 3.889605 43.764988 -3.899606 3.300564 58.367359 -0.565438 15.072942 52.097656 -3.944880 4.674538 30.506721 -12.733358 17.007484 51.415859 5.915243 14.699088 47.157509 9.472696 12.957116 43.820274 25.546583 13.328506 6.787058 20.256720 6.625386 72.610123 6.857947 12.738085 55.520756 -0.200492 4.897668 -14.075600 -4.129310 -99.888702 12.242700 -12.175400 1.793460 -73.881798 -21.205299 -10.473400 -97.361801 -0.003761 -16.680685 -24.319799 -9.534190 -0.586690 -7.946151 -11.378661 14.324373 -3.044477 -2.660707 0.988770 28.773804 33.164738 9.027998 -37.158298 6.736760 0.753047 -79.041283 1.765846 -5.489651 -74.898300 2.012172 -1.178681 -73.309448 -1.363544 -1.282249 -77.409973 -0.359592 -1.762252 -4.024014 11.603423 -6.340339 -81.748970 -2.558103 -0.455561 -50.410931 -8.225019 5.095717 -29.792555 -21.379387 13.529634 -64.799385 -3.233191 -11.085601 -73.941177 -5.706554 6.146854 -29.677490 1.293396 3.069916 -21.893600 158.802994 -187.800003 -38.610767 8.077057 15.334248 82.234940 -3.411146 -14.394004 -5.403615 17.060677 13.840054 -23.093000 -1.250440 18.867300 -24.610674 47.055416 26.863831 65.739044 8.993843 2.570680 -26.623779 -0.103799 -3.240500 -6.459100 -1.284420 -20.489700 0.000000 0.000000 0.000000 -5.747737 32.720135 7.790584 16.695400 -3.517240 -34.793499 -7.400690 -11.501700 -2.398440 34.710400 -1.915210 -2.829720 -26.688400 -7.225650 11.851400 10.138700 14.366000 37.973900 1.191790 -25.536100 -18.985100 1.550110 -27.533701 -19.165100 -19.085199 9.934450 6.255610 -9.304790 28.567400 -25.551001 -5.668870 0.524006 -8.896350 0.604809 -56.147099 -1.193930 -10.023646 -1.126884 23.109486 -3.481822 19.149652 -7.174447 -39.065147 -45.536190 25.544125 34.379902 -11.615000 5.264770 50.618393 -7.831389 4.267599 43.649311 -3.515173 3.013658 58.331570 -1.098468 15.265775 51.933483 -4.029626 4.376918 30.015478 -12.736047 17.117405 50.540352 5.343719 15.370161 48.245647 9.926714 12.959985 43.384186 25.756474 13.099097 6.643106 19.823009 6.900763 72.897873 6.053914 12.646291 55.089924 -0.763171 5.486207 -14.075600 -4.129310 -99.888702 40.464600 -30.242100 -17.017300 -20.181700 28.668100 -21.823000 -72.542999 -0.699025 -14.983671 -24.077999 -9.671500 -0.596437 -8.353056 -11.237301 14.603039 -2.526944 -2.278737 0.547403 28.354410 32.563236 9.011124 -36.731602 7.124240 0.716547 -79.911682 1.615680 -5.533924 -74.886520 2.404698 -0.886619 -73.309669 -1.321840 -1.295209 -77.233276 -0.422056 -1.781983 -4.173236 11.279178 -6.160295 -82.667641 -2.486522 -0.790346 -49.853603 -8.501908 5.035738 -30.014269 -20.502893 13.638197 -65.182671 -3.162919 -11.379423 -73.593361 -5.585517 5.991222 -29.549782 1.002858 2.826115 -21.893600 158.802994 -187.800003 -36.895016 2.017637 -0.221397 59.957428 -5.101931 -12.280166 -35.500011 14.663050 8.664061 -0.000183 -0.871346 7.510360 -26.409214 44.286915 21.410496 52.567356 -1.530401 8.288460 -20.043810 -3.769750 2.910274 -4.390700 -0.060095 -25.990801 0.172402 0.030414 0.176543 -3.364417 33.694702 8.435432 15.616300 -3.522120 -25.795601 4.073690 -1.244680 0.310912 10.963500 -1.829170 -0.462772 -11.585300 -0.943989 0.873985 11.511600 5.321740 21.984100 0.605052 -12.288100 -20.852900 0.621535 -15.349900 -21.020901 -34.513100 23.404900 5.887420 8.914320 -16.714399 -12.254600 16.475401 0.968637 -8.793430 -0.430177 -65.917297 -0.143652 -9.404479 -0.792895 22.901945 -3.898623 18.368340 -7.019250 -39.053658 -45.324814 25.276159 34.758099 -11.611200 5.246160 50.580452 -7.937183 3.808607 43.401783 -3.774564 3.615671 58.466255 -1.473728 14.831913 51.767941 -3.572205 5.043911 30.345997 -13.493806 16.121460 50.710472 5.181095 15.206026 47.871567 9.672275 12.896746 44.251339 25.996979 13.851859 6.675584 19.507677 7.164787 72.959045 6.656430 12.953404 54.990665 -0.255274 4.904225 -14.075600 -4.129310 -99.888702 31.005899 -24.748699 -16.844801 -27.643499 18.126699 25.614401 -56.273201 -0.362839 -11.550500 -24.658100 -9.120130 0.584138 -8.501412 -11.038253 14.149168 -2.633570 -2.552541 0.812105 28.780970 32.825844 8.994361 -37.155399 6.831260 0.570013 -79.154068 1.334565 -6.218478 -75.057922 2.465314 -0.745941 -73.475914 -1.629882 -1.771175 -77.064278 -0.119874 -1.883407 -4.035225 11.354573 -6.005253 -82.303360 -2.875644 -0.702840 -49.841568 -8.566367 4.816158 -30.127699 -21.099215 13.615697 -64.982986 -3.526412 -11.454050 -73.764778 -5.870463 6.233748 -29.211838 0.857568 2.704165 -21.893600 158.802994 -187.800003 -31.435648 -3.708222 1.358339 50.705608 -5.253018 -10.899887 -28.528406 5.490125 10.872534 0.001303 -0.856184 7.337770 -33.035397 30.893030 14.676092 50.848915 8.394535 7.690959 -15.949218 -5.217743 3.648260 -26.148199 0.175086 -8.703600 0.164999 0.056738 0.177165 -1.538208 35.078693 9.401154 8.082210 -2.988330 -21.129200 -1.690840 4.973300 2.097790 2.128230 -1.981380 2.874990 -2.057820 1.468840 -3.178520 14.769600 -3.268390 17.846201 -0.063999 -1.709990 -19.088301 0.091181 -1.542970 -19.631399 -20.449900 24.083000 3.747220 42.095001 -14.004300 21.818100 50.995098 1.190730 -6.132800 8.594220 -37.127102 -4.834450 -8.286107 -0.143870 21.558119 -3.681115 18.097361 -6.800654 -38.784668 -45.066299 24.855055 35.860100 -9.918270 5.209600 50.590527 -7.709770 3.349598 43.054829 -3.852117 3.311593 59.781441 -0.071087 14.698341 51.347572 -3.793422 5.504314 30.613676 -13.626660 15.943212 51.062840 6.761635 14.878691 48.777534 9.883243 13.037369 43.903126 25.614904 13.526888 7.237143 20.708620 6.249568 73.142166 6.835945 12.771478 54.481647 -0.195312 4.528866 -14.075600 -4.129310 -99.888702 16.826799 -29.511101 -10.180200 -37.871700 8.796350 8.248490 -28.582199 -0.368796 -7.597810 -25.019400 -8.604030 0.673423 -8.523572 -11.109726 13.745347 -2.426636 -3.000925 1.161012 28.929651 33.245617 9.193994 -37.556198 6.735000 0.247296 -78.664124 1.398778 -5.623503 -75.244759 2.463488 -1.169272 -73.473892 -1.905683 -1.658023 -77.239479 -0.288246 -2.046458 -4.006197 11.867557 -5.720204 -82.311028 -3.134710 -0.752856 -49.508324 -8.392564 4.863940 -30.144739 -21.423201 13.424057 -65.156418 -3.734896 -11.506801 -73.595947 -5.934083 6.485404 -29.563286 0.863600 2.711845 -21.893600 158.802994 -187.800003 -17.081732 -12.360242 -1.914978 34.131618 -3.641412 -8.953603 -20.102160 7.122688 12.305498 -1.348650 -0.861758 8.218010 -21.073818 20.244719 9.448136 39.403000 11.683076 5.787843 -17.492657 1.766627 -24.839594 -2.956050 -0.095370 3.336120 0.166834 -0.055353 -0.001302 -0.653253 36.825653 10.604236 -4.910550 -0.346243 -21.079599 -11.289500 2.944030 3.758600 24.570700 -5.177400 7.548220 1.291220 -0.309682 0.855960 7.553490 -0.278740 0.684593 -0.235458 0.450113 -15.110100 -0.111325 0.784490 -16.151699 16.829800 10.521300 2.007110 52.833302 11.424400 11.542200 41.943699 2.636540 -1.243120 26.054501 8.868590 -13.215200 -7.090785 0.674392 19.093060 -3.344530 18.767809 -7.137723 -38.545139 -45.290306 24.829279 37.423599 -6.664760 4.629580 51.310223 -7.557714 2.741427 43.057789 -3.978409 3.009593 61.992790 3.297491 14.867387 51.694679 -4.135363 4.955362 29.862431 -13.498265 15.908926 51.069294 10.252941 14.516071 51.269627 10.277334 12.838130 42.653454 24.703621 12.768405 7.692682 23.061653 3.257159 73.778908 6.271980 12.348283 54.112179 -0.315710 4.744758 -14.075600 -4.129310 -99.888702 12.169400 -8.462260 1.487010 -57.040501 -0.049792 -4.746330 -58.769402 -4.544300 -6.556470 -25.156700 -8.756410 -0.153606 -7.984824 -11.211831 13.028322 -2.397929 -3.102569 1.297954 28.039146 33.211147 9.031853 -38.104401 6.743600 0.072719 -78.181282 1.492716 -4.882209 -74.370735 2.019646 -1.172399 -73.119217 -2.105977 -0.978350 -77.752945 -0.996112 -2.270259 -4.806540 11.645254 -5.146205 -82.845673 -3.407219 -0.716007 -49.330139 -8.602364 5.271786 -29.904860 -20.968960 13.518321 -65.818390 -4.202289 -11.464670 -73.243767 -5.344917 6.888686 -30.291742 0.637707 2.566456 -21.893600 158.802994 -187.800003 7.909605 -21.444450 -13.113249 4.141873 -0.704977 -6.004663 -3.371223 14.129146 8.789834 -0.019858 -1.095080 8.019430 6.645032 10.500871 5.831223 6.617055 3.660184 0.757913 -9.188516 14.361482 -15.248857 -0.701626 -0.045792 -0.003026 0.000000 -0.175740 -0.004391
Methastopholis ( ) posted Wed, 29 September 2004 at 5:44 AM
i need help trying to reconfig this bvh in text editer for Mil people Either that or some strong Meds
ockham ( ) posted Wed, 29 September 2004 at 9:47 AM
One thing that stands out in the BVH file is the Swordfish joint. I'm not familiar with Mike, but I'm pretty sure that he doesn't have a Swordfish body part... especially since the "genital" is also listed. Send me the file and I'll see if I can get my BVH Mixer python to help with this, by skipping the bad part! send to occam24@yahoo.com
My python page
My ShareCG freebies
ockham ( ) posted Wed, 29 September 2004 at 9:53 AM
Attached Link: http://ockhamsbungalow.com/Python/BVHmixer2.zip
After looking at BVHmixer, I think it might already do the job. It tries to filter out stuff that isn't in the figure. Try it and see.....
My python page
My ShareCG freebies
PapaBlueMarlin ( ) posted Wed, 29 September 2004 at 10:53 AM
So the python will automatically adjust a BVH file for Dork to match M3?
Methastopholis ( ) posted Wed, 29 September 2004 at 11:31 AM
i hope so papa,files on the way ockham is the bvhmixer new ockham . i usualy get an email when you add someting to the site?
ockham ( ) posted Wed, 29 September 2004 at 11:39 AM
No, it won't adjust the angles to look right on a different model. Sorry!
My python page
My ShareCG freebies
Methastopholis ( ) posted Wed, 29 September 2004 at 12:19 PM
Exception in Tkinter callback Traceback (most recent call last): File "D:Program FilesCurious LabsPoser 5RuntimePythonliblib-tkTkinter.py", line 1292, in call return apply(self.func, args) File "", line 272, in ReadOneBVH File "", line 144, in ReadOneNumber ValueError: empty string for float() ockham what am i doing wrong here
ockham ( ) posted Wed, 29 September 2004 at 12:25 PM
You're not doing anything wrong. It sounds like there's an actual error in the BVH file itself; this message happens when the list of values doesn't agree in length with the list of actors and parameters. Could also be something in the file that my BVHmixer isn't ready to handle. BVH files seem to come in many different flavors! Could you send me the BVH file so I can do a detailed debug? I promise not to redistribute it or anything like that.
My python page
My ShareCG freebies
