Click on Create The choose the area you want to place your object... EG if its a tree put it into Rocks and Trees At the bottom of that window is IMPORT Click on that and then browse to the spot on your Hard Drive where you have place the file.... It will then load in the obp file in the next available empty spot... Use it as per normal.... :) There is no rule that says you have to place trees with trees... You can wack them anywhere but it sure makes them easier to find if they are in a like catergory..
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.
I want it back.
ok, i'm new to bryce and from this site i downloaded some things from the bryce free stuff section. once i unstuff(expand) the file i get a .obp file. from there i would think that i would import it in bryce but to my avail the file is not valid. anyone know what i'm doing wrong? thanks, Nasty P.
