Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Attached Link: http://www.chemicalstudios.com
I have a few particle effect meshes on my site you might try called the splatter pac, and one other splatter that can do wonders sometimes. KenThere's no particle effect per se, but you can get the same effect by using a volumetric material. Create a material in the DTE that is in 3-D, using something like the "spots" noise... and set your ambience values very high (so that it glows). Play around with it enough, and you should be able to achieve the effect you want. Be prepared to spend plenty of time tweaking it, though :^)
I am doing an scene in an industrial setting and need to include a welding affect,intense blue light and shower of blue sparks but am having real difficulty getting it to work.Does anyone have any ideas the best way to do this? any help would be greatly appreciated.
