Tue, Nov 5, 1:53 PM CST
Bryce F.A.Q (Last Updated: 2024 Oct 30 3:44 am)
Subject: Poser textures in Bryce
lexland ( ) posted Tue, 05 October 2004 at 5:50 PM · edited Tue, 05 November 2024 at 9:36 AM
Is there a way to export a model's texture in Bryce? When I import a saved obj from Poser to bryce I get a search window for textures... Is it enough to locate and open the texture file or do I have to make some adjustment? Thanks!
Rochr ( ) posted Tue, 05 October 2004 at 5:55 PM
Attached Link: http://www.rochr.com/posertobryce.html
You will need to make some small adjustments Heres an small tutorial on the subject.
Rudolf Herczog
Digital Artist
www.rochr.com
EricofSD ( ) posted Wed, 06 October 2004 at 12:40 AM
Also, you can use Grouper from Castironflamingo and that will reduce some of the adjustments. And the DAZ turbo importer is probably the slickest import program there is. I use the turbo importer on the Corel B5 version and its fine. There is some manual work but not nearly as much as a strait import. Rochr's tut is good for strait imports and even for Grouper imports. But after getting turbo importer worked out, and using Studio as an intermediate between Poser and Bryce, I think that would be better for complex scenes that require a ton of textures to be located.
lexland ( ) posted Wed, 06 October 2004 at 3:26 AM
Thanks!
EricofSD ( ) posted Wed, 06 October 2004 at 9:44 PM
Do keep in mind that Rochr's method is very important to know for Bryce.
lexland ( ) posted Thu, 07 October 2004 at 6:11 PM
I already put it in my favorites! Thanks Ericofsd! And Special thanks to Rochr too!
