That's the problem with HDRI images - they will display the base HDRI image in the background. This makes for great lighting and reflections, but it will also introduct a background that you may want to mask in some situations. In general, HDRI images work best on metallic objects, inserted in a high quality photograph, or in a background that does not include the ground or the sky (if you don't have an image with enough resolution).
The whole thing was an experiment: firstly to test Vue's ability to import Daz figures via Poser.
Secondly to see how unrealistic objects looked in a realistic environment. Placing the figures directly against the photographic background made for a greater contrast between real and unreal. It illustrates Agiel's point well: metal or inanimate objects work best.
Rokol, Vue 5 comes with 5 HDRI images supplied by www.doschdesign.com. Well spotted! I've used HDRI in Carrara 3 for engineering product images so I'm looking forward to comparing v4 Pro to Vue 5.
Cheers,
Mark
UD Hatchling dragon is a direct import and came out a little bright and shiney.
Knuckle-cracking Freak was partially re-textured in Vue 5. The model importing process misread some of the figure labelling i.e. 8 or 9 sets of fingernails, most of which were actually head parts. There are also a few seams showing tho' this could be my recolouring as the mislabelled body parts were a tad confusing.
The Robot has been completely retextured using Vue 5 materials with very minor tweaking and, I reckon, came out best. Note the reflection in the visor.
I tweaked Vue's OpenGL settings for speed as things slowed down on my box with all three charaters loaded (AMD 3200 1GB Radeon 9800 Pro). But it worked fine.
Now all I need is $600 for a decent HDRI program. Donations anyone? ;-)))
Message edited on: 10/06/2004 06:45
Cheers,
Mark
