Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
If you're using the P4 renderer you'll find this problem is insurmountable. Nostrils also display the same characteristic. Using Firefly and playing around with the shadow bias will cure it. I can't remember the specific setting for shadow bias, unfortunately.
Someone (Duane Moody maybe?) made a morph that fixed the nostril problems in the basic P4s and the first generation Mike and Vicky. It might still be in freestuff.
The cast shadows check box is not only on the light properties, but also on the body part properties, like the head, and on the render settings. The draft firefly mode's render settings do not have cast shadows checked by default to save time. Try checking cast shadows in Render/Render Options.../Render Settings to turn off the light in the mouth. Jeff
This is a pet peeve of mine, too. FYI... professional FX houses use a technique involving a special secondary render pass that uses "one-bounce to camera only" ray tracing count called an Occlusion Pass (usually w/ Renderman or Mental Ray) to determine if areas of a surface are concave (like mouths, nostrils, armpits, and other body skin-fold crevices) and use this extra render pass in a clever composite to darken those areas, since they would by nature recieve less light than their surrounding regions. I've tried with no success to duplicate this occlusion pass effect with firefly. Since others have dealt fairly well with the nostrils already (look in freestuff) I've been toying (slowly and intermittently) with the workaround idea of creating a "dark translucent morphing mouth ball prop" that will partially fill the open mouth and darken it appropriately -- it's a little tricky, but if I meet with any success I will share it with the community. Anyone else's input and sharing would be great, please let me know!!
Darkening mouth textures is defintely another tool, which I use also, especially if the figure is distant from the camera and closeup mouth details are indistinct. (I didn't mean to overlook your good suggestion earlier.) The trouble with just darkening the textures though, is that unless you remap the mouth, teeth and tongue in variable sections, you have to darken them uniformly; When you're going for true photoreal shadowing in a closeup image, the front facing teeth, the front of the tongue, and sometimes even the front-facing back wall of the throat need to be brighter, with a gradient intensity falloff to the innermost non-facing concave portions of the inner mouth -- and this becomes even more tricky when the light is coming from side, high, or low angles relative to the head position. That's why I thought using some kind of a semi-translucent, layered, and positionable "darkmouth blob" object might be the thing to do, if I can figure out a useable implementation of it. Obviously, all of this is getting very picky for shadow realism -- but that's the kind of stuff the professional occlusion passes achieve, and I'm just trying to figure out how to match that level of quality. When you see a CG creature with and without occlusion darkening, you'd be amazed at the comparative extra level of realism you get from a relatively subtle change like this.
I just bought Poser 5 and am beginning to try and learn it. One very irritating thing I have noticed in my renderings is that, when the mouth of the model is open, the light inside is unnaturally bright. It really destroys the realism. All of the lights are set to cast shadows. What am I doing wrong?
