Thu, Nov 14, 10:55 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Where are my plants from Vue 4?
regaltwo ( ) posted Thu, 14 October 2004 at 9:52 PM ยท edited Wed, 13 November 2024 at 10:56 PM
I just installed the upgrade from Vue 4 to Vue 5, and there's a problem. When I go to the plant thing, it only shows new plants, and none of my old ones from Vue 4. How do I add the old ones to this?
nhirschberger ( ) posted Thu, 14 October 2004 at 11:51 PM
Click on 'Plants', n o t the sub-folders. Norbert
dadamson ( ) posted Fri, 15 October 2004 at 1:04 AM
I found all of my plant, by either clicking on the Main folder or by clicking on New COllection and pointing at the Vue 4 plant floder. However, when I choose a plant it says I can't use that vegetation. These are all of the extra vegetation I purchased from E-on. Any Ideas? Thanks
wabe ( ) posted Fri, 15 October 2004 at 1:26 AM
Well, you can shift the two subfolder entries (AlienPlants, Edited Plants) in the collection window to the higher level to get the look you was used to. One of these little new things i enjoy a lot - to be able to change the order of collections and even have subfolders. Super! The extra vegetation. You find new versions for V5 on the Vue 5 disk. You install them again and enter the serial numbers you have. That should work.
dadamson ( ) posted Fri, 15 October 2004 at 2:42 AM
thanks! I will do that! And I LOVE being able to reoder the collections, as well as being able to see the subfolders, rather than having to add them one at a time.. There are so many little enhancements in this version that I keep finding... and loving!
martial ( ) posted Fri, 15 October 2004 at 4:44 AM
It will be good if you say if it will be working or not.When i have installed Vue4 Pro, the extra plants bought for Vue4 never works with the Pro version,even i used the version on the Pro cd and serial numbers received when i bought them
nhirschberger ( ) posted Fri, 15 October 2004 at 5:19 AM
I think the activation code for the extra vegetation is only valid for the Vue serial number you transmitted to e-on to get the activation for the plants. So if you update or install a Vue version with a new serial number you have to repeat this process. Norbert
regaltwo ( ) posted Fri, 15 October 2004 at 7:38 AM
Ah. Thanks. :)
dadamson ( ) posted Fri, 15 October 2004 at 4:38 PM
Ok, that's good to know because, I never got it to work with Vue Pro either. LOL. I will definitely contact them about the problem.
