Tue, Jan 28, 3:54 PM CST
Photography F.A.Q (Last Updated: 2025 Jan 22 8:17 pm)
Subject: About focal length
DJB ( ) posted Tue, 19 October 2004 at 1:39 AM ยท edited Tue, 28 January 2025 at 3:51 PM
On the shooting data for this shot it reads 67.7 mm I have not taken any courses of anykind in photography as I tend to learn from logic.So does this mean the focal length is the distance from what the lens first focuses on to 67mm further back? I was about 4 metres away from these ducks. And no Donald you don't have to look at these LOL
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
DHolman ( ) posted Tue, 19 October 2004 at 6:12 PM
No no no!!! You have to put the Duck WaRnInGs in the header. It's too late after I've already seen them. And look at the weird one with his head on backwards!!!! HOW IS THAT NOT EVIL???!!!!!! Anyway, focal length is the distance between the center (optical center) of the lens to the focal plane (film or sensor). -=>Donald
DJB ( ) posted Tue, 19 October 2004 at 8:37 PM
But if I warned you.. You may never have replied. Thank you. I will read more about this now.
gwfa ( ) posted Wed, 20 October 2004 at 3:45 AM
Doug: be warned to refer to focal length allways (if you are using a digital camera, for the sake of comaparability) rescaled to 35mm film format - the conversion factor depends on the camera type (i.c. the sensor size)....
Gerald
DHolman ( ) posted Wed, 20 October 2004 at 3:55 PM
Focal length for digital cameras isn't calculated any different than for film cameras. People just use the wrong terminology. When someone says a 50mm lens on a Canon EOS 10D has a "focal length of 80mm", what they are trying to say is that the 50mm lens on a EOS 10D has the "angle of view of an 80mm lens". The focal length remains 50mm. It's another one of those things that just pokes me the wrong way (like the companies and media calling it a Multiplying Factor and not a Cropping Factor). -=>Donald
Tedz ( ) posted Wed, 20 October 2004 at 6:26 PM
How insensitive to get Donald with the Duck...it will drive Him "Quackers"
LostPatrol ( ) posted Thu, 21 October 2004 at 4:59 AM
Attached Link: http://www.sweeting.org/mark/lenses/
This link may help you understand the effect of lens crop. Like Donald says a 50mm lens is a 50 mm lens whatever camera it is on, the difference being that on a 10D etc not the entire lens is used therefore giving the effect that the lens is of a longer focal length than it actually is As I understand it this means that a percentage of the outer lens view is not used (what a waste of quality glass)
The Truth is Out There
FearaJinx ( ) posted Wed, 27 October 2004 at 12:26 AM
pretty ducks
