Mon, Jan 27, 7:36 AM CST
Subject: Can anyone explain Mikeys 2 part eyebrows, esp with Legecko textures
kiru ( ) posted Wed, 29 November 2000 at 9:07 AM ยท edited Sun, 26 January 2025 at 4:39 PM
I can get them to work right? What settings and textures get used between the two I would assume that Eyebrows would be the skin texture, and the upper would be the hair with bump and trans. Any help greeted fondly Kiru
JeffH ( ) posted Wed, 29 November 2000 at 7:09 PM
I don't think any one uses the "Upper" eyebrows, everything is made for the ones attached to the figure.
JOE LE GECKO ( ) posted Thu, 30 November 2000 at 6:56 AM
Make both eyebrows transparent ( trans_min and trans_max to 100% with no transparency map ). Use a light color ( white is better ) for skin tone and this should be ok :) If you want transparency maps for upper eyebows, you can use great brows and lash trans map by Newt ( in freestuff ) or mine on my site... joelegecko
