Are you ripping out the geometry and saving it out as an OBJ file or are you outputting an OBJ and referencing it ?? This probably isn't your problem, but sometimes when I manually create an OBJ from what I have stripped out of a prop file (cut and pasted into a text file and saved as an obj file) I have to run it through UV mapper...then it shows up. If that isn't it, there are a couple of other things that you can check for. --Rebekah--
In ripping out the geometries from a PP2 file I get weird results in one of my files. In clicking on the icon in Poser 5, the prop seems to be there (parameter dials, it's listed)but it is invisible. Any help would be appreciated. I've checked { and spaces. everything seems to be OK.
