Thu, Feb 27, 4:02 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
Subject: I got a question about the Poser 5 Library
akura_ ( ) posted Fri, 22 October 2004 at 6:27 PM ยท edited Thu, 27 February 2025 at 12:48 AM
Is there a way for library to auto arrange folders by name in the program library. Under the Poser 5 library folder, all my content is aranged by name from a to z, is there a way to do that in the Poser 5 library? Please help.
Jackson ( ) posted Fri, 22 October 2004 at 6:40 PM ยท edited Fri, 22 October 2004 at 6:42 PM
I'm not sure what you mean, but if you're talking about changing the order of the pallette (Character, Pose, Props, etc.), I strongly doubt it.
Message edited on: 10/22/2004 18:42
thefixer ( ) posted Sat, 23 October 2004 at 3:38 AM
You can change the order in P5 by going into folder options in the main folders and change it to "type" or something else instead of by "name" which is what it sounds like it's on now. You can also add folders in your library pallet with P5 to make finding stuff easier ( additional runtime not needed in P5). For example in the Characters folder of your library pallet, make a sub folder for Mike3 and another for V3 for instance or you could just do a sub folder for DAZ stuff. Do you see waht i mean here. The same can be done in the props folder or any other folder in the pallet library. For instance, Poses, make sub folders for "mat" poses and another for actual positional poses and another for character inject poses. This is how mine is set up and I find it really easy to use.
Injustice will be avenged.
Cofiwch Dryweryn.
ynsaen ( ) posted Sat, 23 October 2004 at 3:52 AM
Both of them are right. The top level library folders -- cahracter, props, pose, face, etc -- are hard coded into the system and must show as they are. If you change them, they will vanish. That said, if you are really hip with XML, you can rearrange the order of them. But doing so will likely drive you batty.
cedarwolf ( ) posted Sat, 23 October 2004 at 9:18 AM
Ok, now, I've apparently hit on a snag here...I've got a bunch of files inside a major folder that are not in alphabetical order. Some are all the way at the bottom of the list, some go automatically into the list in the proper place...how do I get the list of files I see to correct itself and alphabetize a - z?
Bobbie_Boucher ( ) posted Sat, 23 October 2004 at 9:27 AM
Do you have some stuff in lower case? I do believe Poser puts lower case letters below upper case. The remedy is to make sure the first letter is always capital.
thefixer ( ) posted Sat, 23 October 2004 at 12:03 PM
Folder management isn't just a case of how Poser does it. If you go through the "view" tab in the drop down menus of where your folders are then you will see another side menu saying "arrange icons by" and then that gives you other options like "type, size, name etc." Tick whichever of these you want to display your sub folders or folders in. Bobbie Boucher is right also, a slight change like upper or lower case or a letter in the wrong place will make a difference.
Cofiwch Dryweryn.
akura_ ( ) posted Sat, 23 October 2004 at 12:12 PM
"Ok, now, I've apparently hit on a snag here...I've got a bunch of files inside a major folder that are not in alphabetical order. Some are all the way at the bottom of the list, some go automatically into the list in the proper place...how do I get the list of files I see to correct itself and alphabetize a - z?" thats what I was trying to ask.
Bobbie_Boucher ( ) posted Sat, 23 October 2004 at 1:23 PM ยท edited Sat, 23 October 2004 at 1:23 PM
Yes, and that is the question I answered. Unfortunately, Poser decides to have TWO alphabets:
1.) First letter is capitalized
2.) First letter is not capitalized
Your solution is to make sure the first letter of every name is capital.
Message edited on: 10/23/2004 13:23
akura_ ( ) posted Sat, 23 October 2004 at 2:31 PM
ok, thanks
MustangMike ( ) posted Sat, 23 October 2004 at 5:42 PM
If you change the case of the first letter on a Geometry, Character or Texture folder, won't that screw up the reference in any .cr2 file that calls them?
diolma ( ) posted Sat, 23 October 2004 at 6:05 PM
Changing the name of the major folders (those that poser expects to find automatically) will almost definitely cause a problem. Changing the names of files/folders within folders will not cause a problem unless some other file refers to that file folder. Windows file/folder names are case insensitive. for windows "A" = "a". Poser's filing system is case sensitve. "A" most certainly does not = "a". (guess: this is most probably likely to be due to the fact that Poser has to work cross-platform,; Windows is case insensitive, but Unix (and the Mac) is not.) Since the original post was about the ordering of files within the (poser) libraries, the answer is: No. You can't do that within Poser. What you CAN do though is re-name the various files/sub-folders (using an external app. eg, if you're using windows, the explorer) within the top-level folder. The only problem I ever had using this approach was with the DAZ inj/rem all MAT poses. The original files expected to be able to find the various sub-files where the installer had loaded them. (I found an update on the DAZ site which appeared to cure this, but by then I'd already edited the inj/rem all pz2s so that they worked.) Sorry if this post seems garrilous and unconnected; it isn't (but my mind is a little..) Cheers, Diolma
Bobbie_Boucher ( ) posted Sat, 23 October 2004 at 9:13 PM
You don't want to change the names of Geometry files or folders. Poser will go nuts if it can't find that stuff. You can change the names of the folders within the Libraries. Example: change "Morphing clothes" to "Mike's Clothes." You can change the names of individual items within Libraries. Example: change "Michael's Shirt" to "Mike's shirt." You could change the names of Texture folders if you got the free version of CorrectReference (CR). You might not want to go through all that work. CorrectReference Pro (CRPro makes everything much easier. But you have to buy it.)
