Tue, Jan 28, 11:55 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 10:51 pm)
Subject: Poser 5 to Poser 4?
speedgoat ( ) posted Mon, 25 October 2004 at 9:41 AM · edited Tue, 28 January 2025 at 11:52 PM
Is it possible to convert/downgrade a Poser 5 pz3-file to make it work in Poser 4?
xantor ( ) posted Mon, 25 October 2004 at 1:10 PM
Yes, if you load it into poser 4 and save it out again it will be a poser 4 version but material room specific settings wont be converted ( obviously ).
speedgoat ( ) posted Mon, 25 October 2004 at 1:12 PM
but it won't load because it is a Poser 5 Dokument :(
bobcat574 ( ) posted Mon, 25 October 2004 at 1:42 PM
all my poser 5 loads into poser 4, it just says 'the file is a newer format than expected, poser will attemp to read it anyway', click ok and your in.
Estruch ( ) posted Mon, 25 October 2004 at 1:51 PM
Attached Link: http://www.iespana.es/bodrieros/
I'm not have problems, but if you save the archive created one document Poser 4.
wheatpenny ( ) posted Mon, 25 October 2004 at 9:58 PM
Site Admin
The only way it might be a problem is if the file uses any P5 specific features, like materials, or dynamic hair.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
xantor ( ) posted Tue, 26 October 2004 at 6:16 AM
Try renaming the .pz3 to .cr2 and put it in a figure library and click on it like loading any figure, if it still doesn`t work then there might be some problem with the pz3 file.
raven ( ) posted Thu, 28 October 2004 at 12:43 PM
Also make sure you save it as a .pz3 file and not as a .pzz (compressed) file.
xantor ( ) posted Thu, 28 October 2004 at 9:18 PM
Compressed files should work the same way as uncompressed ones, they use gzip compression which is the same for poser 4 as for poser 5.
raven ( ) posted Fri, 29 October 2004 at 2:23 PM
xantor, Poser 4 doesn't use compressed files, only Pro-Pack and Poser 5 do.
xantor ( ) posted Fri, 29 October 2004 at 2:31 PM
Sorry, I forgot about that. :[
