Tue, Jan 28, 11:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 10:51 pm)
Subject: Poser 4 or Poser 4 w/pro pack?
Sarte ( ) posted Mon, 25 October 2004 at 2:26 PM · edited Tue, 28 January 2025 at 11:52 PM
Which one of the two would you recommend, as my computer is too low-end to support P5?
Do the impossible, see the invisible
ROW ROW FIGHT THE POWER
Touch the untouchable, break the unbreakable
SnowFox102 ( ) posted Mon, 25 October 2004 at 5:51 PM
What do you consider "low-end"? I'm running P5 on a 400Mhz Pentium2, with 128MB RAM, and Win98. THAT is low-end ;P Runs ok for me, though large models and scenes react slowly (like the MilDragon) There's not going to be a lot of difference between the P4s and P5 speed wise. I'd say go for P5 anyway, but try the P4PP demo first. If you can run that you can run P5, though the dynamic stuff may be tough (I haven't bothered to try those on my computer, it'd crash most likely.)
dayjo ( ) posted Mon, 25 October 2004 at 5:59 PM
I strongly recommend ppp, I've had p5 and don't think it's up to much hope they do better with p6.
bobcat574 ( ) posted Mon, 25 October 2004 at 7:14 PM
I've run my poser on a 150 mgz 486dx running win 98 and 96 megs of ram. Slower than molasses in january, but it run. If you want all the little quirks of poser go for p5, but if you just want it for creating and exporting to other programs, pro pack is the best. (I run both).
sturkwurk ( ) posted Mon, 25 October 2004 at 7:23 PM
I still user Poser Pro for most of my renders, check out my gallery sometime.
I came, I rendered, I'm still broke.
wheatpenny ( ) posted Mon, 25 October 2004 at 9:55 PM
Site Admin
I would say PPP if for no other reason than to get rid of that very annoying problem with geometry rsr's where the file refuses to open so you have to delete the rsr. PPP doen't use rsr's so it doesn't have that problem.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
SnowFox102 ( ) posted Mon, 25 October 2004 at 10:50 PM
P5 doesn't use rsr's either, it uses png thumbnails.
Little_Dragon ( ) posted Tue, 26 October 2004 at 2:28 AM
Further advantages of Pro Pack over P4:
2D motion blur
additional file-format support
a few animated material options
the Setup Room for rigging your own figures
file compression
Python scripting
Jaqui ( ) posted Tue, 26 October 2004 at 2:55 AM
and for ppp:
lower hardware requirements.
stable reliable release ( 5 may be there now have no idea )
most people here have it and can help with questions.
for p5:
bleeding edge ( latest and greatest waste of funds as per societie's current practice )
most freebies and products are now only in p5 format.
DominiqueB ( ) posted Tue, 26 October 2004 at 8:56 AM
Actually the most supported version is P4, P5 support is slowly gaining ground, but still no official support from DAZ. The only reason to get P5 is for the material editor which has a learning curve but is much more powerful and also for the rendering engine which is of better quality. But a better rendering engine usually eats up more ram and cpu. I would go with ProPack, no more bum files, and no more rsr thumbnails.
Dominique Digital Cats Media
Tguyus ( ) posted Tue, 26 October 2004 at 1:50 PM
If you want to do any animation, definitely pro pack because of python support. I can't live without python any more, so can't live without pro pack. Many other advantages as discussed in earlier posts. good luck...
SnowFox102 ( ) posted Tue, 26 October 2004 at 4:39 PM
IIRC P5 supports Python too. I know there's a Python script option under the File menu.
