Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Attached Link: http://market.renderosity.com/%7Evue/backroom/faintlines.JPG
I'm not sure if the effect really is the same, but maybe the attached link to the backrooms helps. NorbertIf this is the case, clipping the unwanted part of terrain would be the solution
My two cents
Paul.
Thank you all for the response, I am using Vue 3, the version that was free from 3D World. You are right the water effect is a terrain given a clear liquid material assignment. I was having trouble controlling the water function, simulating turbulence, it was much easier to play with the surface using a terrain but I seem to have found a major flaw with that line of thinking. Gary
