Fri, Feb 7, 12:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: need help from a kind soul....
skee ( ) posted Wed, 27 October 2004 at 12:11 PM ยท edited Fri, 07 February 2025 at 10:19 AM
I downloaded a free figure (BattyGuy) from www.combat-bunny.com and no matter where I put the files,I can't seem to get it to load in poser pro. I know where the files are to be put (object in geo, cr2 and rsr in char, etc.) but no matter where I put them the figure will not show in poser. Could someone download the file and see if I am missing something? there are 2 obj files, and no rsr file for main figure. I have contacted the site for info and they say it should work.The cape shows but no chacacter. Any help......thanks skee
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
wespose ( ) posted Wed, 27 October 2004 at 12:24 PM
Whats up skee, I just downloaded the Battyguy, I'll check it out for you. It sounds like theres a missing png file. I'll get back to you when I know all the specs. for sure.
skee ( ) posted Wed, 27 October 2004 at 12:28 PM
Thanks, it's about to drive me Batty...
skee ( ) posted Wed, 27 October 2004 at 12:35 PM
I tried opening the object files in bryce and everything worked, I had to change one of the figure files name to batty1 . That way I could tell which was which. All of the free figures( from this site) do the same thing. They will not open in poser.
Roy G ( ) posted Wed, 27 October 2004 at 2:44 PM
One BIG problem is there are two obj. files of the same name. And for some reason the zip file structure would put them in the Geometries folder (where they should be.) But the cr2 looks for them in the characters folder.
The obj file for the cape is included but, isn't called for in the cr2. Instead the cape is imbedded in the cr2 file. Which is why that's the only thing that loads.
Here is how I fixed it.
Use the smaller of the two obj. files and put it in a folder, Runtime/Geometries/BattyGuy/
You don't need to copy over any of the other obj files.
Edit the cr2 file and change the lines
figureResFile :Runtime:libraries:character:4th Party:BattyGuy.obj
to
figureResFile :Runtime:Geometries:BattyGuy:BattyGuy.obj
I would also edit the cr2 to point to wherever you put the texture file.
Have fun
skee ( ) posted Wed, 27 October 2004 at 3:29 PM
Thanks Roy I will give it a try. skee
skee ( ) posted Wed, 27 October 2004 at 3:56 PM
RoyG , it worked like a charm....Thanks Thanks. It seems all of his figures have the same problem. I will email him and let him know.
nomuse ( ) posted Wed, 27 October 2004 at 4:44 PM
So to find Batman, you called on Bruce....I mean Bryce?
Roy G ( ) posted Thu, 28 October 2004 at 5:20 AM
I'm glad I could help. :)
