Thu, Jan 23, 8:32 PM CST
Forum Moderators: Staff
Subject: Please view my character
smalll ( ) posted Fri, 29 October 2004 at 12:04 AM ยท edited Thu, 23 January 2025 at 8:07 PM
I made a character. And I apply it some pose. But, the foot is far from shin. Only foot! Why? Is there any solution? I want to foot near shin. Foot must cling to shin. You can download my file. http://www.visionmode.co.kr/001/runtime.zip Please help me...
Helgard ( ) posted Fri, 29 October 2004 at 1:02 AM
I have downloaded and installed the file, and everything works right for me. What poses did you try to put onto the figure. Some poses may contain parts that your figure doesn't have. For instance, the DAZ figures also have a part called buttocks, and two neck parts, and that may be what is causing this. If you use poses for Posette or any of the P4 people, does this still happen?
Your specialist military, sci-fi, historical and real world site.
smalll ( ) posted Fri, 29 October 2004 at 3:22 AM
Thanks Helgard! It work right in poser 4 pose. P4 pose is allright. But, I still want to know. Why it does not work in poser 5 poses? Please help me...
moochie ( ) posted Fri, 29 October 2004 at 4:44 AM
Hi. There's a step (pardon the pun) that you've missed. You need to set the rotations for the different body parts .. you've just used the default settings. I believe you can do this in P5, but I've only just got P5 myself, so haven't ventured that far yet. But there's a free program called PHI Builder that will set rotations for you. Get it here http://www.royriggs.com/poser.html The learning curve isn't too bad and look for Dr Geep tutorials in the main Poser forum here, which explain all about rotation settings. Couple of other things .. your model doesn't have any toes. The Poser figure poses you're applying do. That's a problem because I suspect the poses assume the user has IK turned on for the legs (it's on by default). Your figure has no IK and no toes, which is forcing the foot away from the leg when the pose is used. That's my guess. Good luck.
kaveman ( ) posted Sun, 31 October 2004 at 1:51 AM
How does it look with a full render, I sometimes get this in preview??? or Box mode but when I render it looks fine. Using P5 with standard figures.
daveH ( ) posted Sun, 31 October 2004 at 7:41 PM
actually, as far as i know, the leg ik stops with the foot, so the toes, or the lack thereof, are of no consequence.
moochie ( ) posted Sun, 31 October 2004 at 9:11 PM
Good point, well made. The inky chain does, indeed, stop at the foot. Whoops.
smalll ( ) posted Wed, 10 November 2004 at 12:16 AM
You gave me great help. You let me know the problem is about 'IK Chain' Thank you very much. You gave me great help.
