I don't have a number for you, but if you look at the UV template you could estimate the surface area covered by the head compared to the surface area of the body on the map, and then calculate that the head should normally be 1/6 of the body's LINEAR Y scale. Use that to calculate the relative sizes of the bump maps (linear dimension) which will produce the same scale bumps in Poser. You can see the template by examining the OBJ file in UV Mapper or you can download a seam guide or template from here - there may even be a template in the Poser installation, but I haven't looked to verify that.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=975406
See the link above for a previous thread with a 4:1 test render.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Does anyone happen to know what the scale difference between Posette's head and body is? I am attempting to apply a bump map to the entire figure and I can't for the life of me seem to get the scale of the bump to match up.....
<-insert words of wisdom here->
