Hi, Pogmahone. I use a similar effect with terrains quite a lot (duplicate terrain, massage it's dimensions/orientation a tiny amount and give new texture, depending on the effect I'm after; being a newbie still, it takes me a LONG TIME to get things nearly right), but I'd never thought of using the same technique on rocks! Thanks for the info! Cheers, Diolma
why not add it to the tutorial section pogmahone? This post will be difficult to find after a while. It would have been a nice tut I think :o)
Attached Link: http://www.pinhead.robbes.com/tutorial/Mario/mg_CTATerrains.htm
I use this sort of technique a lot. MarioG has great tutorial on a similar technique with terrains.This is not my "second childhood". I'm not finished with the first one yet.
![file_137706.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_137706.jpg)
Having messed round in the DTE trying to make a convincing mossy rock texture, I chanced on a much easier way to achieve better results. Obvious to experienced Bryce users, but might be useful for newer users :^)Make a rock, keep clicking and deleting on the rock icon until you find a shape you like, then texture it. I usually use a terrain mat rather than a rock mat. Name it stone1 so you can locate it later on.
Message edited on: 10/30/2004 15:07
