Wed, Mar 11, 5:25 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 10 6:08 pm)
Subject: Can't save as morph target? New problem with P4...
TygerCub ( ) posted Sat, 06 November 2004 at 9:13 AM ยท edited Tue, 10 March 2026 at 1:56 AM
I've lost functionality in my export features. The image above shows what I can check... and that's it. I've been using P4 for years and never had this problem before.
I noticed it when trying to export an object for morphing; I cannot check the box for, "As Morph Target(no world transformations)".
Then, I discovered I can no longer check several other selections either! The only thing I seem able to check is, "Include figure names..." & "Weld body parts..."
Has anyone else run into this? What in the world would cause it? Is there a fix? I can reload the whole program again, but would really rather not if there is an easier fix.
gaz170170 ( ) posted Sat, 06 November 2004 at 10:08 AM
Erm...sure you`re in the right section?
TygerCub ( ) posted Sat, 06 November 2004 at 11:17 AM
{looks at heading... scratches head in puzzlement... WTF?) Nope. Totally wrong place. Sorry 'bout that!
xantor ( ) posted Sat, 06 November 2004 at 4:55 PM
Does this happen with everything or just one figure?
TygerCub ( ) posted Sat, 06 November 2004 at 7:33 PM
Happens with everything now. I tried uninstalling Poser and reinstalling it, but no joy. It's still not letting me select certain items. Besides the original problem it also won't let me reset the parameter dials with new limits. Sorry 'bout posting in the wrong forum. I bounce back and forth and was just sooo frustrated, I didn't notice I'd bounced to the wrong spot.
TygerCub ( ) posted Sat, 06 November 2004 at 7:37 PM
Now I'm really confused. Did someone relocate this to the proper forum? I looked up top when posting the original message and it said POSER... the first reply was in VUE forum... now this one is back in POSER???
LilWolff ( ) posted Sat, 06 November 2004 at 10:06 PM
Not a Fix but a Work around I was told about: I still use it. When you try to save your export and come to that point where the export features (as shown above) don't work - Open up your edit pad and then you should be able to check all boxes. I know sounds weird, but it does work! :-) You will have to do this each time you want to export something using the selections you can't pick otherwise.
TygerCub ( ) posted Sun, 07 November 2004 at 7:15 AM
My biggest concern is why it happens in the first place. I've used the export function dozens of times before and it never refused to work right. Now suddenly a lot of the functionality is gone. I did uninstall and reinstall Poser, but the problems remain. This leads me to believe it's something external... a bug in the system, perhaps, which is a very scary thought.
