Sat, Jan 11, 10:32 PM CST
Subject: Largest file that can be created in Bryce?
speters ( ) posted Sat, 06 November 2004 at 1:35 PM · edited Sat, 11 January 2025 at 10:09 PM
Attached Link: http://www.stevepetersdigital.com
I am a Photoshop retoucher and was looking into Bryce. I was wondering what the largest file is that can be rendered in Bryce? Also, can you get enough detail that you could blow something up to 34"x16" @ 300dpi? I want to create some grassy rolling hills, and wonder if the grass would be photo realistic at this size? If so, could someone please send me a close up of some grass? Thanks steve@stevepetersdigital.com
pogmahone ( ) posted Sat, 06 November 2004 at 1:54 PM · edited Sat, 06 November 2004 at 1:59 PM
Your website looks nice, but I'm too dumb to figure the navigation out :^(
Brycetech is the one who'd be best at answering your question, I think.
Edit to add - DUH! found the image choices when I scrolled down. Great images!!
Message edited on: 11/06/2004 13:59
Erlik ( ) posted Sat, 06 November 2004 at 2:17 PM
The largest you can render in Bryce is 65535 x 65535 pixels. It's 218 inches per side. But the actual size depends on your memory and the space on your hard disk. I tried just once, to see how would it come out. The Bryce BMP was more than 4GB in size. A little too much, ain't it? :-) Anyways, what you want would be 10200x4800 pixels and is not a problem. The problem is, Bryce doesn't have a good procedural grass for closeups. So you'd need to import grass from something like Grass or Twig or whatever. That's for foreground. You can see an example in my gallery in Heart's Ease Lake. That grass might have been a bit better, but I messed bump maps, although it still looks pretty good. I rendered that at 2600 x 3500 and it looks pretty much the same. http://www.renderosity.com/viewed.ez?galleryid=570467 The other way is to do what Flak did: used bits of grass photos and arranged them around. That would look even more realistic, you'd just need to take care with arranging so you don't get a pattern. See "Ri'aka Field (s07)" in his gallery. http://www.renderosity.com/viewed.ez?galleryid=569685 For the background grass, you can always use Bryce terrains, the way I did for the background forest. But you'll get only straight tall grass. You might mess with the textures to get that wind-blown look, though. Or mix photos/models with Bryce terrains... Hope this helps a little.
-- erlik
foleypro ( ) posted Sat, 06 November 2004 at 2:29 PM
Yes Bryce can Make awesome Realistic Renders...Check my Gallery out..I use Bantam Grass which is one awesome Freeware program...I have had over 400,000 Polys which came out to be like 100,000 Blades of Grass in a Render for a Client...Which i cant show until they Approve it but it came out very nice...One Scene I am working on has over a Million Poly's just in Grass alone and I am thinking on Boosting that up even more... As for Render sizes I usually Render mine out at 3200x2600 @300-600DPI or Better for Postwork and it always shows up Nicely...
electroglyph ( ) posted Sat, 06 November 2004 at 3:52 PM
You can render anything to disk. Here's one 36x24inch at 150dpi I did for a proposed summer camp. It took about 10 hours to render with default settings no AA. If you double the resolution to 300dpi you can expect it to take about 4 times as long to render. Your best bet is to work at 800x600 dpi and get everything set up then render to disk the correct size and go to bed.
TheBryster ( ) posted Sat, 06 November 2004 at 9:23 PM
Forum Moderator
Biggest I did was 303mb, 12million polys, about 15,000 objects. Bryce started to groan a bit by then!
electroglyph ( ) posted Sun, 07 November 2004 at 8:32 AM
Bryce file size on mine was not that big for this one, only about 80mb. Notice the filesize on the render BMP is about 57MB. If you do a Bryce render to disk at your proposed size be sure you have around 1GB or more free disk space to hold the BMP file. Once it renders you can save it as a jpg and only take 4-5MB but you'll need 200-300MB for the rendered file plus some space to do things with it and save it. Nothing sucks quite like doing 2 hours of postwork and doing a save only to find that you have no room to put it on your drive. I also get to about 300mb bryce files and my computer starts to groan. It takes hours to save and the screen takes a couple of seconds when I move the camera. That can be fixed with ram. I usually only render these files at 1600x1200. I do post at double the final resolution then scale to 800x600 for the challenges/etc.
Ornlu ( ) posted Sun, 07 November 2004 at 7:41 PM
Bryce can render an image as large as your page file can handle... So not a problem. I've had a bryce scene that was several hundred megs and rendered a large resolution image of it and it was fine. if time is no obstacle
