Thu, Jan 9, 11:51 AM CST
Forum Moderators: Staff
Subject: about morph
smalll ( ) posted Thu, 11 November 2004 at 8:06 PM · edited Thu, 09 January 2025 at 6:14 AM
Hi! I'm studing poser5. I'm beginner user of poser. I want to make morph. So, I exported light forearm of Barney. And I modified it in Rhino 3D. And I appled it right arm. But, it's position is moving. Why does it? Can you give me helpness? Please... You can see it in website. http://www.visionmode.co.kr/001/poser-morph/002.html
mateo_sancarlos ( ) posted Thu, 11 November 2004 at 11:15 PM
Either redo morph without any vertical translation, or import morph as obj to Poser, position correctly, then export and apply morph.
lesbentley ( ) posted Fri, 12 November 2004 at 12:24 PM
Some how the position of of all the vertices in the forearm have been moved. Most likly reasons, you did not use the 'Export as Morph Target...' option when you exported the object, or you moved the whole object in Rhino.
smalll ( ) posted Fri, 12 November 2004 at 7:22 PM
Thank for mateo_sancarlos and lesbentley's kindness! I solved it!
