Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
The one in the middle was done with the shadow/highlight function. For the one on the right I copied the image to a new alpha layer. This layer is b/w. Then invert the layer and use that as a selection (CTRL+click). Then I used this selection as a layer mask for brightness/contrast.
For the attached image I did basically the same as before, only I used a levels layer instead of a b/c layer. The reason I'm playing with this is to find a technique that works nicely on other software that hasn't got the shadow/highligt filter of PS/CS :)
Message edited on: 11/12/2004 20:00
What is a friend? A single soul dwelling in two bodies. -
Aristotle
Glass Eye Photography =- -= My Rendo Gallery =-
You can always use the 'quick and dirty' method too. Open the image, then use image > Adjustments > levels. Then go to 'history', click on 'open' this reverts the image to it's original state, then choose the history brush, click next to, not ON 'levels' and paint away to your hearts content, returning the 'leveled' colour to the subject. Like I said quick and dirty, but it works ok. i never really use shadow/highlight.
The technique your using 3DGuy is called contrast masking.... and it does work... I've seen this technique in various photo magazines.
I thought we had a tutorial on this somewhere in the resource center area? Just checked and I guess I'm remembering wrong, because I don't see it. Maybe we just discussed it in the forum?
Bet they'd love it if you made a tutorial on it..... :~) The only other thing I would add to this, is that in order to avoid having to fix it in the first place would be to use a bit of fill flash for proper exposure of the subject, or spot meter the bird and set the exposure manually based on the meter reading of the bird, not the background...
Message edited on: 11/12/2004 20:51
I am, therefore I create.......
--- michelleamarante.com
Fill flash would be nice, but this was a full zoom on a 300mm lens effectively 450mm.. fill flash that :) So this method is already known.. hmm and I thought I was being creative haha..
Aristotle
LOL! Ehhh.... screw the flash then....must say it is nice and sharp though!
Attached Link: http://leppphoto.com/Project-A-Flash/
I saw a guy using fill flash for nature shots once. He had a normal flash (a Vivitar 285HV I think) but he had mounted a fresnel lens to it. This concentrated the flash and allowed him to do fill at longer distances. I -think- the link above is the one he was using. Trying hard to remember if this is the one he said. -=>DonaldMessage edited on: 11/13/2004 06:56
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Now that is a nice little gadget .... thanks for that link Donald.
I'll see if I can whip up something comprehensable. I've got no idea on how to submit that though ;)
Aristotle
There's a tutorial up in the Resource center about this now o/
Aristotle
What is a friend? A single soul dwelling in two bodies. - Aristotle
-= Glass Eye Photography =- -= My Rendo Gallery =-
