Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
You should try to open and compile one of the shader examples, it's the easiest part to start plug-ins. The examples should compile with VC++ 6 without any modification to do. One thing is required though, it's the Rez files. The cookbook explains how you can get them. And if you can't, I can send them. And you may need to modify the CopyMCX.bat file to automaticaly copy the new files in your extension folder. But that's the only thing to do as I remember.
I asked them simple question to get me started with VC++ to implement new plug in for Carrara. Someone said read the cookbook. I already did and it did not give me enough to get started with VC++. I only know VB and SQL.
I bought Visual Studio. Would someone please kindly to get me started putting stuff in VC++ to make plug ins.
Thanks
Message edited on: 11/12/2004 22:07
