Jeff... This is an amazing image!! Coming from me "Postwork Maniac"........ It's Perfect the way it is. The reason I'm saying this: # 1 Due to the fact that there are multiple reflections of the girl, whatever you do to one... It would be maddening to get them all identical. #2 The lighting in this is Spot on for this scene. Only One Suggestion for PostWork.... A killer Presentation with some Sci Fi style Lines for Frame Work. If you would like some Examples, I can post some and where to get the PhotoShop Brushes. Again...Superb Work!! ICM
___
Ockham's razor- It's that simple
Duplicated the main layer, Desaturated completely, Used a couple muted lens flares (just for white enhancement) on the white spots of her dress. Then cut the opacity of that layer down to 30% allowing the colored image to show through. On the colored layer I used Blending options: inner glow(red diffused), outer glow Gray(precise) for a sharper line. Then a Tech brush at the bottom with a gradient effect.
Mostly what I originally said with the exception of less color.
(I shoulda known better, LOL, Always gotta mess with it)
Sorry to paint on your Image.
Let us know when you finish.
ICM p.s. (a few jaggies from dropping down the JPEG format)
Message edited on: 11/16/2004 20:40
___
WOW! You guys are so kind. I also like the image as it came out of Bryce but I just thought there might be something that could be done that would take it even way beyond. Thanks for the suggestions. Moongoat, I did output a "distance mask" for the purpose of doing some depth of field blurring so I might give that a try. ICM, thanx for your tips. I like to think of myself as knowledgable with Photoshop but I've not ever done the blending modes you described with the glows. I will tinker with that for sure. And I like the edge brush effect. And yeah, tell me about where to get some of those brushes (and some examples of their use?). If anyone else has any more ideas I am still open. I may go ahead and work on these tips and post it from these and then post another one with later ideas.
I don't have a website, or webpage and am trying to figure out how to set one up at one of those free provider sites. When I get it put together I will make available a few files, such as the .br5 file of this room of mirrors (without the characters) and the files I used to make the marbles (in another gallery image).
