Wed, Jan 22, 11:05 PM CST
Subject: Bryce to Poser export/import
ravenfeeder ( ) posted Sun, 10 December 2000 at 10:52 AM ยท edited Mon, 29 July 2024 at 4:18 AM
I'd like to create 3D figures in Bryce and export them as 3D figures to Poser. I can go the other way by exporting 'obj' files from Poser and importing them into Bryce, but can't find a way to go Bryce to Poser. I'm told there's an unsupported export feature in Bryce. Anyone know how to do this?
KenS ( ) posted Sun, 10 December 2000 at 2:58 PM
Depending on what your exporting, Bryce 4 will export terrains and lattices by selecting the object and going to File/Export Object, Or you can export Bryce object Presets (.OBP)or Materials(.MAT) and Skies(.BSK) by selecting the preset and clicking export. If your wanting to export a 3D Mesh(.obj,.3ds,.dxf, etc.) select the object and click the "E" next to the model to Edit/Smooth Mesh. When that small window appears hit CTRL+D or COMMAND+D and Save As window opens, choose the format you want and hit save.
Skygirl ( ) posted Mon, 11 December 2000 at 2:56 AM
But if you use boolean works in Bryce when you create your 3D figures, you cant use FastTraxx method. FastTraxx, does there at all exist a way to get a Bryce boolean 3D model out of Bryce as a 3ds, obj, dxf file ?
ravenfeeder ( ) posted Mon, 11 December 2000 at 7:40 PM
Well, what I really want to do is create things more complex than a terrain. For example, I tried to create a booth, such as one might find in a restaurant. No problem creating it out of various shapes, but couldn't export it to Poser. I was not able to select the whole thing to use the routine you gave.
Skygirl ( ) posted Tue, 12 December 2000 at 1:27 AM
Ravenfeeder ! When you build a 3d-model in Bryce and you want to export it out of Bryce as a - let say - a 3ds-file for use in an other program...Poser or what ever...you cant use FastTraxx method if you have use boolean work or Bryce primatives. If you do that you have a Bryce-model and youll never have anything else. What you have to do is to go to the Bryce free stuff section and download Caligulas exportable primatives and use them for building in Bryce. FastTraxx tip is perfect if you import a non-Bryce-file into Bryce and want to export it out again in its original file-format.
Skygirl ( ) posted Tue, 12 December 2000 at 1:35 AM
Forgot something !!! Its not enough to select your items, you have to group them as well when you do what FastTraxx told you to.
KenS ( ) posted Tue, 12 December 2000 at 3:53 AM
Unfortunatly, Bryce will not export booleans at all, only terrains and lattices. Ken
Skygirl ( ) posted Tue, 12 December 2000 at 4:44 AM
Oh well...something to wish for in Bryce 5 :- ) Skygirl
karbuk ( ) posted Sat, 13 January 2001 at 11:19 PM
does Bryce 3D export anything other than the pictures and textures? Trying to get terrains out. Im running Bryce 3.1 Thanx
