Wed, Jan 1, 9:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 5:26 pm)
Subject: Dress for Miasaki, some problems.
Torulf ( ) posted Wed, 24 November 2004 at 12:46 PM ยท edited Wed, 01 January 2025 at 8:57 PM
Dress for Miasaki after improvments. Now I have grouped the dress in C4D and made an UV-map. Ins better, but not useful. 1 UV map. 2 Dress before saving in library. 3 after loaded from library. The thigh seems to been moved back from hip. 4 Conformed. The dress not goes to her back. What is wrong now? I wonder if there are too many polys?
TG
nickedshield ( ) posted Wed, 24 November 2004 at 2:14 PM
When you made the dress did you use Miasaki as a mannikin? If so, did you zero her out before using? If you used the obj from the Geometries folder there is an offset problem.
Torulf ( ) posted Wed, 24 November 2004 at 3:40 PM
Yes I used her as mannikin. I exported her as obj in default pose. Imported her with recomendested 900% scale. Im new in this how do I do for zero her?
TG
nickedshield ( ) posted Wed, 24 November 2004 at 4:33 PM
When you load her, turn off the IK's, Figure Command, then go to the Windows Command, locate the Joint Editor and open it. Make sure you have selected the figure then click on Zero Figure. Your figure should straighten up. Then export this figure as an obj and use it for you mannikin.
