Wed, Jan 1, 3:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 3:25 am)
Subject: Soften expressions
ikercito ( ) posted Wed, 24 November 2004 at 7:20 AM ยท edited Wed, 01 January 2025 at 3:27 AM
When applying expressions they're usually too exagerated, any way of toning them down..?? Like when you apply an "anger" expression it seems to be "somebody burned my house, I'm gonna kill everyone on the neighbourhood"... could it just be "shite! I lost my keys again"... I mean, could the expressions be applied in a partial (some percentage maybe?) way, without the need to fiddle all the morph targets in the face manually..?
Ike.
Message edited on: 11/24/2004 07:22
Candid ( ) posted Wed, 24 November 2004 at 11:09 AM
  1. apply the expression
  2. Figure->Create Full Body Morph
    (name it as you wish)
  3. select 'Body'
  4. at the parameters tab - new parameter (Other)
    Decrease it as much as you want.
Greetings: Candid
ikercito ( ) posted Wed, 24 November 2004 at 2:33 PM
Yes, it works but... it softens the rest of the morphs I have used in the body and the face. Anyway, it might just be impossible to do what i want, it doesn't really matter I'll tweak the dials manually like always do. Just thought there might be some quicker way... Thanks Candid!
Candid ( ) posted Wed, 24 November 2004 at 3:57 PM
ok, there is another way.
  1. Select head
  2. Apply the expression
  3. With the head still selected
    Object->Spawn Morph Target (give it a name)
  4. Look at parameters, in 'Morph', there must be the morph you've just created. Decrease it a little.
It must be affecting only the head (not the other body parts)
Well it will affect the other head morphs but that is unavoidable if they are affecting same points.
Greetings: Candid
movida ( ) posted Wed, 24 November 2004 at 8:22 PM
You can also (before you use the expression) load the default figure with no expression; apply the expression as frame 30 of an animation. Back up to frame 1 and cycle through until you find a degree of the expression you like. Then save it. It's work but...
