Ditto. If you've already scaled the things to match, uncheck everything on the OBJ import panel. You're probably getting random sizes because the "percent of figure size" is checked. This tries to adjust every OBJ to the same size.
My python page
My ShareCG freebies
Loading OBJ files is not really a problem but I have troubles in making anything "conforming" or "fitting" Every time I import and OBJ it seems to have a "random" size. Even if I import different parts of the same mesh I have to scale everything again. What is the thing I am doing wrong ? I use MAX with the habware OBJ exporter plugin.
