Thu, Nov 28, 10:54 PM CST
Subject: Boolean
ISSE ( ) posted Sat, 27 November 2004 at 6:01 PM · edited Thu, 28 November 2024 at 8:22 PM
Hi,It is 1.47 of Mnight Here is Istanbul,since some days I Have been working to learn Bryce and took some steps,read too many tutorials,also learned boolean operations and is something that I didnt understand,can anybody please help me?? In boolean operation I can see the result after render image ok,but after boolean operation since both previous positif and negative object are seen together on the screen, how can I put a new object between them ??for example how can I execute window frame for the window hole opened by boolean operation??It is very difficult..is there any mean of getting rid of negative object.?? Thanks a lot for your kind answers,good nights,evenings or mornings everybody..
Claymor ( ) posted Sat, 27 November 2004 at 6:28 PM
Typically a positive object is outlined in solid lines. A negative object is outlined in dotted or dashed lines. That is you first visual clue. You want the "window hole" to be somewhat visible so you can see where to place the frame. One suggestion that might help is to assign a different color family to your negative objects. The picture shows a negative cube (selected) inside a positive one. To assign a new color family click on the colored square icon and choose a new color. In this case I have already chosen green. The negative objects will show outlined in dotted green lines now. By assigning a consistent color to your negative objects you can distinguish them even more easily from the positive ones.
striving ( ) posted Sat, 27 November 2004 at 7:44 PM · edited Sat, 27 November 2004 at 7:46 PM
Sorry, not sure if this is what you are asking or not. But if you want a new object visible inside the boolean, just make the object NEUTRAL. This object will NOT be effected by the pos/neg there already.
I think that is what your above is asking...
Message edited on: 11/27/2004 19:46
TheBryster ( ) posted Sat, 27 November 2004 at 8:58 PM
Forum Moderator
If you've booleaned a hole in a wall you can boolean a window frame in another part of the screen and then just move it to where the whole in the wall is.....the two won't affect each other. 1 create/boolean a hole in a wall 2 create/boolean window frame 3 move window frame into hole in wall. Hope this is what you are looking for....
pogmahone ( ) posted Sun, 28 November 2004 at 2:14 AM
Attached Link: http://www.renderosity.com/gallery.ez?Form.SortOrder=UserName&Start=55&Artist=ISSE&ByArtist=Yes
Ooooohhh....had to go and check your gallery to see if you're the same ISSE who made some of my favourite Terragen images, and you are :^) Some people on this forum have been discussing Terragen recently, wondering about its capabilities, so for those......attached is a link to a page in ISSE's gallery. Read 'em and weep! I wonder if you're asking about how to identify the negative primitive while working in wireframe? You can change the colour of the wireframe by selecting it, and clicking on the box shown. You can name it as well, which helps when trying to select it later - makes it easy to find in the drop-down box at the bottom of the work area.
ISSE ( ) posted Sun, 28 November 2004 at 2:53 AM
Good morning ..I had a problem as I go bed in midnight,I found it solved when I wake up by the friends all over the world.I like the forum.Many thanks for the friends who are so kind to give answers to my question,I tried what are written above,really work excellent.Pogmahone exaggerate my talent in terragen,I am apprantice yet next to Masters. Thanks a lot again everybody
