Fri, Dec 27, 1:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Aiko3 Takes SP3 MORPHS! Yes it's true!!
starlight64 ( ) posted Sun, 28 November 2004 at 2:44 AM · edited Fri, 27 December 2024 at 1:01 PM
Hi all, We were disscussing a simular topic in a thread about millenium unimesh characters sharing morphs, so I tested it. Using Morph manager I loaded a "loaded" SP3 and and empty Aiko and transfered a bunch of morphs. Saved it and Walla! It works! I didn't try using inj direct but didn't think it would work. Anyhow... If you have SP3 and her morph paks you can have a fully loaded aiko in about 20 min if you can use Morph manager! (I am gonna have to check but if I can do it, I may just share the cr2 w/ whoever wants it that has both Sp3, her morphs, and Aiko3 installed. See below.. one w/ the brownish lipstick is stock Aiko w/ one of my own tex from my "Soft n lovely for V3 applied. The other one is my result after lot's of playing and all that glitters from Daz applied. Rhonda
gillbrooks ( ) posted Sun, 28 November 2004 at 5:19 AM
This is interesting..... Did you see a thread yesterday...giving David Aiko's morphs too ?
Gill
Engel47 ( ) posted Sun, 28 November 2004 at 9:53 AM
This is very interesting - can this only be done with morph manager, and where would I get this? And is it possible to share the CR2 with those that have all the required installs??
PapaBlueMarlin ( ) posted Sun, 28 November 2004 at 11:07 AM
Can you do with the LE version?
starlight64 ( ) posted Sun, 28 November 2004 at 2:48 PM
"Did you see a thread yesterday...giving David Aiko's morphs too ? " Yes, I saw the thread but didn't look at it. Making Aiko into a male was not my first priorty right now.lol. But it is interesting cause the people at Daz one of the things that would not work would be V3 and M3 morphs because of the difference in the cut of the mesh and extra body parts for the females, even though the vertices are the same #, that they are not distributed quite the same. I would imagine that some of them probably do work though. "This is very interesting - can this only be done with morph manager, and where would I get this? And is it possible to share the CR2 with those that have all the required installs?? " Any Cr2 editor would most likely work Or you can edit one w/ wordpad (cringing) if you are really knowledgable and have a lot of time. :D You used to be able to get it here but now you will have to go to: http://www.morphography.uk.vu/dlutility.html I am not sure about sharing the Cr2's. Use to, you could. But I think some things were changed when some of the newer meshes came out. I am gonna check into that. I looked at the cr2 in text and it don't have absolute references so YES I would say it can be done But can we do it Legally? I may just have to figure out how to make some cool character inj to share. ;D Also an almost full Aiko on my puter is huge! 49mb! "Can you do with the LE version?" Well of course! That's what this thread is all about papablue! Making Aiko into a more usable character w/o having to spend a bunch more money! Take care all! Rhonda
queri ( ) posted Sun, 28 November 2004 at 3:00 PM
I have no real knowledge how to encode RTE, but Dodger shares his cr2's in an RTE encoded form that codes to a Daz obj in your geometries file-- so you have to have the Steph morphs in order to use the cr2 on your Aiko. Problem is-- I don't think there is a way to encode RTE to two different objs. AIko and Steph for instance. Why don't you contact Dodger--he hangs out over at PoserPros, Look for the Aeon forum. He could help, even though he has a character who can use All the unimesh morphs plus Aiko. Plus does a really cute male version. All he can say is no. You can tell him I sent you-- it won't get you further, but then he can dump on me rather than you if there's a problem.:)) rte encoding is free and available for PC and MAC. EMily
