Thu, Nov 14, 4:18 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Subject: No expressions with Vicki
geronimo8 ( ) posted Wed, 01 December 2004 at 3:20 AM · edited Thu, 15 August 2024 at 8:59 AM
Hi everyone! I'm a Poser newbie having a problem with wicki's expressions. I just installed vicki, loaded the figure but when I doubleclick on an expression (for example one with opben mouth) nothing happens. I can only change the pose of the figure. What am I doing wrong? I hope someone can help me. Thanks G.
SamTherapy ( ) posted Wed, 01 December 2004 at 3:59 AM · edited Wed, 01 December 2004 at 4:00 AM
You need to inject the expression morphs before anything happens. That is, assuming you have V3. The other two come with the morphs built in.
Message edited on: 12/01/2004 04:00
geronimo8 ( ) posted Wed, 01 December 2004 at 5:37 AM
What do you mean with "before anything happens"? (yes I have V3). I load a blank vicki figure and try to inject an expression, no chance...
SamTherapy ( ) posted Wed, 01 December 2004 at 6:07 AM
You can't inject an expression. You load an expression, or create one, by using an expression preset or twisting the parameter dials. In order to do this you must have the head morphs pack. To create your own expressions you need to inject the morphs first then play around with the dials. If you're trying to INJ an epxression pose from the library it will automatically find the necessary morphs. Question - you did buy the head morph pack from DAZ, didn't you? Otherwise, none of the above will work.
geronimo8 ( ) posted Wed, 01 December 2004 at 7:34 AM
Yes, I did also buy the head morph pack, but it doesn't work :( I'm slightly going mad on this... Just to be shure: loading an expression from the head morph pack means doubleclicking on the Icon with the desired expression on it, for example the mouth with a tounge hanging out, right? So when I doubleclick the expression, with the pre-installed expressions from poser it works fine on a standard figure. But when I try to do the same thing with a DAZ expression on Vicki3, nothing happens.... Geronimo
Jackson ( ) posted Wed, 01 December 2004 at 11:23 AM
  1. Do NOT use "V3 BLANK." You can't inject morphs into her. 2) Use "Victoria 3 sr1." 3) Inject the head and expression morphs you need. 4) Turn the dials or load the expression made for v3. NOTE: the Poser pre-installed expressions are for the characters that came with Poser. They probably won't work with DAZ characters.
geronimo8 ( ) posted Thu, 02 December 2004 at 1:59 AM
Thx for you Help guys, I finally got it ;) Isn't it possible to edit the face in poser's face Editor? It just tells me that this is no known Poser Figure...
Geronimo
GladysClump ( ) posted Thu, 02 December 2004 at 2:39 AM
The face room is for the poser5 figures, Don, Judy, etc.
geronimo8 ( ) posted Thu, 02 December 2004 at 2:43 AM
Thanks! I think Im ready to start now :)
