Fri, Nov 22, 7:02 PM CST
Subject: Last Call For Help!
Inspired_Art ( ) posted Thu, 02 December 2004 at 5:20 AM · edited Sat, 02 November 2024 at 9:26 PM
Ok, if I don't get anywhere with this I am throwing in the towel on trying to do this.... I have Victoria 3, along with Xtreme CloseUp and even something called btsculptor - Real Pubes for Victoria 3 Whatever I try to do, I just can't get the pubic hair to show up. I talked with DAZ, and followed their instructions with little success.
Eddy
randym77 ( ) posted Thu, 02 December 2004 at 7:50 AM
Make sure you have the Pubic Hair dial set. (It's a Body morph.)
If that's not it, post a screen shot of your material settings.
Inspired_Art ( ) posted Thu, 02 December 2004 at 12:04 PM
Ok, here are the settings, no morph dials are appearing
Eddy
Inspired_Art ( ) posted Thu, 02 December 2004 at 12:06 PM
Here's what I get with this setting once it's rendered
Eddy
Inspired_Art ( ) posted Thu, 02 December 2004 at 12:12 PM
Switching to Pubic Hair in Material drop down produced the same results
Eddy
randym77 ( ) posted Thu, 02 December 2004 at 12:36 PM
Which V3 textures are you using, and are you using the included MAT pose files to apply them?
It looks to me like you don't have any textures applied. You've got a bump map applied to the torso (which I suspect is supposed to be applied to a genital prop, not to V3). You need a texture map. Bumps, as the name implies, give an object bumpiness, but for pubic hair, you need a texture map.
Rance01 ( ) posted Thu, 02 December 2004 at 2:57 PM
In the material you've Skin Torso selected for Figure 1. I suspect that if you scroll down the list you'll find the body part you're trying to texture. I don't have V3 so I don't know the names of all of her material zones ... Good Luck, Rance
